It is currently Wed Jun 25, 2025 3:43 pm
 Post subject: subframe
PostPosted: Sat Jun 21, 2008 9:47 pm
hi all
i am going to do a engine conversion i was told $6000 will do it. but all i need to do is to get someone to cut the subframe and the rest i can do my self how much would it cost to get the subframe cut by a pro?
thanks
PostPosted: Sat Jun 21, 2008 11:21 pm
High heel ninja
$6000 seems way to cheap, Brad 13secmini did his conversion & it cost him over 10K and he did all the work himself pretty much,
Talk to Mr Enforcer in regards to the subframe
PM minimad he'll happily tell you all about a starlet conversion (i assume thats what your doing) he's just gone through it all.
Good luck, i can't WAIT to see how it goes.
The Tool
PostPosted: Sun Jun 22, 2008 4:52 pm
Find someone who's done one (legally), and be very nice them, and get a frame built at mates rates to the same spec as theres, that way you know it'll pass engineering with the same engineer.
PostPosted: Sun Jun 22, 2008 5:30 pm
6k will be like being up a S%#@ creek without the paddle, i dont think 6k will quite do it... Cutting the subframe has got to be the easier part of the subframe process??
Life's a garden.... Dig It!
PostPosted: Sun Jun 22, 2008 6:10 pm
Why dont you just buy one for sale?
I know where there is a Morris with a 4EFTE conversion already done, all paint and bodywork done with wheels etc for about the same price ($6,000)
This would be an easier route as most of the work has already been done.
PostPosted: Mon Jun 23, 2008 5:54 pm
Hi,
If you are thinking that you can do it yourself once it has been cut.
You must have welder and so on?
I think you can save cost more buy doing cutting yourself as well as making it.
All you nee to do is make a subframe jig as long as it keeps mounting to body fix, you can use anything....well, wood might not be good!
This was one I made with scrap tubes I found at my work.
Good luck
Atchi
