It is currently Tue Jun 24, 2025 10:14 pm
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 37, 38, 39, 40, 41, 42, 43 ... 125  Next
PostPosted: Sun Jun 01, 2008 9:10 pm
As always pure exellence Tricky,looking good
cheers Hallsey
PostPosted: Sun Jun 01, 2008 9:41 pm
This space for rent
Tricky, with that motor in you can almost touch it! 8) 8) Not long then? ;)
Am I the only one who cringed looking at that modified brake pedal? I'm sure you've got it covered, but part of me don't like the look of that..
PostPosted: Sun Jun 01, 2008 10:35 pm
Its looking good as always tricky... And to what sgc said, i think we just need a finished picture or maby one a little more finished, seeing it in the raw for makes it look a little suss :lol:
Life's a garden.... Dig It!
PostPosted: Mon Jun 02, 2008 8:24 am
damn that fits like a glove !
lookin hella neat and i love the mandrel bends to
Mearcat wrote:
PostPosted: Tue Jun 17, 2008 6:07 pm
any updates tricky?? :D
1992 Toyota Starlet GT EP82
PostPosted: Tue Jun 17, 2008 6:46 pm
Soon! :D
PostPosted: Tue Jun 17, 2008 7:34 pm
how soon ??? :P :P :P :P
i can feel the boost comin on from here 8) 8)
Mearcat wrote:
PostPosted: Wed Jun 18, 2008 7:54 am
Finished!!!!
:lol: :D :) :( :o :shock: :? :x :roll: :wink:
PostPosted: Wed Jun 18, 2008 9:30 am
you had that pictured tucked away for a time like this didnt you tricky! ;) :lol:
PostPosted: Wed Jun 18, 2008 9:56 am
Nice pussy :-)
PostPosted: Wed Jun 18, 2008 11:30 am
Yes Rude, I did.
I like the pink bits!! :shock:
PostPosted: Wed Jun 18, 2008 12:11 pm
nice i like it alot. :lol:
Cheers Dan
PostPosted: Sun Jun 22, 2008 7:03 pm
Hi Gang,
Time for a quick update. I have changed the direction of the Completion Strategy for El Gato. After some quick consultation with those that matter, I have decided to get the car completed to a state whereby it drives and is virtually complete, save for the bodywork and paint. This is for three reasons:
1. If I gave it to the spray painter now, on past performances it would be another 7 months before I got it back.
2. If I have the car complete to the point whereby its running and driveable, then there is less chance of missing those little bits like holes for cabling etc that could be missed. And I want these included as when its painted, every screw hole, penetration and cut will be finished and the new paint will remain unmarked.
3. Completing it to a running state in the next month or so will allow me to show it off at the QLD Mini Muster, and create some interest for QBR (and also get on the dyno run and take that out as well :shock: )
So, to this end, the car is going back together, with the car in a magnificent shade of undercoat grey! Here is some pics of this weekends efforts.....
The engine is now in for the 2nd last time - with the new Exedy HD clutch installed, new timing belt, gaskets etc. I am really impressed with the MKIII subframe and how easy it is to get the motor in an out. The brake MC is in as is the pedal box.
The front suspension and components are in. The lower control, arms which are Group A spherical jointed items are in, but awaiting some spacers to be machined (thanks Simon!), and the tie-rods which are also spherical jointed Group A items are also in. I like how they look, and like even better the ease of which they can be adjusted (on-car!).
The GAZ coilovers are in for the first time - and they look great. Can't wait to test them out on the track! The discs, drive flanges and calipers are all in and bolted up! :D
Looking through the headlight opeing, they look like something you would see on a Group N rally car or similar (easier to believe if the discs were twice the size):
And the rear subframe showing of its new livery of satin black 2-pak, is in now in and ready to recieve the rear suspension and brake components.
This week and weekend will see the clutch MC installed and the clutch lines, all the brake lines and prop valve, brake booster, rear suspension and brake components, exhaust and basically everything that feeds into the engine bay. Hopefully, I will be able to complete the fuel delivery system as well.
See you then!
Tricky
PostPosted: Sun Jun 22, 2008 7:09 pm
This space for rent
Great to see some progress there Tricky 8)
Is your accessory blue a hint of things to come at the painters? ;)
PostPosted: Sun Jun 22, 2008 7:20 pm
I have contenplated doing the same thing many times Tricky... But the van is still way to far off for even that stage :cry:
