It is currently Fri Aug 01, 2025 1:15 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
 Post subject: SU Tag Numbers
PostPosted: Mon Jun 02, 2008 9:48 pm
Can anyone tell me the Tag numbers for the Twin HS2 SU's on a MK2 Cooper S
PostPosted: Mon Jun 02, 2008 9:58 pm
Would i be correct in saying AUD440L and AUD440R?
PostPosted: Mon Jun 02, 2008 10:11 pm
I'm no expert...
(but Google..)
Lists (most likely UK.. Aus same??)
1969-71 as AUD440....
1964-69 AUD146..
http://www.somerford-mini.co.uk/pdfs/Catalogues/Fuel-and-Exhaust-Systems/10.%20Carburetters%20-%20Twin%20HS2%201961-71.pdf
http://www.burlen.co.uk/partList.aspx?pump=&carID=10848
PostPosted: Tue Jun 03, 2008 9:05 am
Mk1 is : AUD 146 L & AUD 146 R . Mk2 is : AUD 440 L & 440 R . Carb bodies have on them AUC 870 & AUC 871 for Mk2 and AUC 1340 & AUC 1341 for Mk1 ...........
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Tue Jun 03, 2008 9:22 am
can you buy these tags anywhere?
mine have been removed
PostPosted: Tue Jun 03, 2008 12:19 pm
My SUs have a mk2 manifold, mk2 bodies and mk1 tags....
They're from an early mk2 (mk1.5 to some) so may be yet another case of parts bin craziness..
PostPosted: Tue Jun 03, 2008 2:30 pm
Not sure , you could possibly get them made up as they are just a triangle of aluminium with tiny numbers and letters stamped on them (a jeweller or engraver should be able to engrave them like the original stamping) but the easiest way first up would be to put a wanted up for the tags . The one from the left hand carb might be common to some other mini at the same time , not sure about the right hand one though . Someone might have one on a carb that's not going on a car for an accurate resto and doesn't really care if it is right or not .
PostPosted: Tue Jun 03, 2008 4:05 pm
I sold a set of carbs a while back, and the number of emails I got asking for the tags on their own without the carbs was kinda annoying...
PostPosted: Wed Jun 04, 2008 4:36 am
Burlen - as mentioned in the 3rd post - offer them although the modern font is different to the original.
Pip, pip old boy
 Post subject: Re: SU Tag Numbers
PostPosted: Tue Dec 22, 2015 12:46 pm
Resurrecting an old post here.
Just looking at some replacement 1 1/4 " SU Carbs for my 7/70 Mk2 : is it correct that as noted above that the Mk2 should have the AUD 440 L & 440 R tags whilst the Carb bodies have on them AUC 870 & AUC 871?...or is there varying situations to this from early to later numbered cars?
Thanks
ex 1976 Mini 'S'
ex 70 Morris Cooper S Mk2 - ex Police
ex 68 Morris Cooper S Mk1
1970 Morris Cooper S Mk2 - '73 Bathurst replica
70 Morris Cooper S Mk2 - under resto
PostPosted: Tue Dec 22, 2015 2:08 pm
Thanks
They are the correct numbers for your car. Do you have the AEG573 manifold and thin Smiths PCV valve?
Also - here is a photo of the aftermarket tags that can be purchased from Burlen. I bought a set when doing up a set of MK1 carbs and they look nothing like the originals.
PostPosted: Tue Dec 22, 2015 3:02 pm
Some time ago I mentioned the different font to Adam Bressington (SU Midel - http://www.sumidel.com/index.html) and I think he said he had the original style stamps so could re-stamp blank tags for an authentic look.
PostPosted: Tue Dec 22, 2015 3:08 pm
Has anyone here purchased tags recently in the correct font?
 Post subject: Re:
PostPosted: Tue Dec 22, 2015 3:13 pm
You may find them on fleaBay, but, you realise that the Carbs will no longer be original and any prospective new owner should be informed of this change :!: :lol: :wink:
PostPosted: Tue Dec 22, 2015 3:33 pm
Where were the tags attached to the carbs?
1993 R32 Nissan Skyline GTR
