It is currently Thu Jun 26, 2025 11:45 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Post subject: turbo mini!
PostPosted: Tue Jan 25, 2005 6:58 pm
Does anyone know of anyone with a turbo mini in the western sydney area?
I just got a turbo, exhaust maifold and dump pipe from brickworx and am anxious to get the thing onto my car.....
just would like someone with some knowledge about what sort of cam etc to use....
i plan to use graham russel to set it up but i would like other peoples ideas just to see if other people have come up with anything interesting....
cheers everybody,,,,
68matic: "i havent seen much head in my life "
PostPosted: Tue Jan 25, 2005 7:10 pm
That was a quick delivery.
PostPosted: Tue Jan 25, 2005 7:20 pm
PM boostedmini, he runs a similar setup to what you propose. :wink:
PostPosted: Tue Jan 25, 2005 7:34 pm
yeah twas wasnt it? he only sent it on friday right..... damn quick.... i was shcoked to find it in my office this afternoon....
cheers kev.... now i have the turbo i am just trying to find a engine and box to borrow to make the steadies for the turbo....
PostPosted: Tue Jan 25, 2005 8:47 pm
Don't forget you need to cut 1/2 the firewall away to fit that turbo- unless you do what kazjim did, and stick it above the clutch.. :P 8)
PostPosted: Tue Jan 25, 2005 9:10 pm
yeah i already have the manifolds to "stick it above the clutch" :)
I cant wait to get it in the car.... Power away!!!!!!
after the needed mods....
PostPosted: Wed Jan 26, 2005 8:47 am
does anyone know he difference with a standard HIF44 (1 3/4" Su) and the metro turbo carby which is stilol a 1 3/4"Su....
PostPosted: Wed Jan 26, 2005 9:30 am
Yea, the HIF-6 from the Metro Turbo has a few extra passages in it to pressurise the float bowl and reversed throttle shaft seals to keep the mixture in the carb....
Also O'rings on the Suction chamber
J
PostPosted: Wed Jan 26, 2005 4:00 pm
so in all reality i cant run a standard su, it has to be a turbo unit? i would like a turbo unit, but they are quite hard to find it seems....
PostPosted: Wed Jan 26, 2005 7:03 pm
IF you ran a standard SU, you would have higher pressure in the "venturi" area than the float bowl..... instant leanout.. leanout = heat = detonation = melted pistons . . .
Not a lot of fun ......
Unless you use it in "Draw-through" mode (Carb, Turbo, Engine) then it is totally normal operation.... you just need to ensure that the turbo has an oil seal as it will now be running in a vacuum.... you calso cant usea BOV or an Intercooler.... Oh and cold starting is a bitch and throttle response suffers.... but hey, I'm biased !
J
PostPosted: Thu Jan 27, 2005 2:21 pm
right, now i understand.... Definately want to run both intercooler and blow off valve.... and I dont want to lose any respoinsiveness, thats what makes them fun.....
you have a turbo car aye kazjim?
PostPosted: Thu Jan 27, 2005 5:03 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
he dose i think he shoul call it the farm mini cos it is very agricultral
but at the same time it is also very well done and works well
makka
PostPosted: Thu Jan 27, 2005 5:13 pm
just out of interest how much did brickworx charge you for those parts?
PostPosted: Thu Jan 27, 2005 5:16 pm
e was very reasonable.
$150 + postage.. The turbo seems in decent nick, though I am going to have it serviced or rebuilt if its deemed necessary by GR...
The manifolds seem to be a mox of professional and home made... But they should work well and they came wih heat wrapalready on them.
The only problem i think i might have is that they seem to be for a cluby or moke, as they are a very tight squeze into my round nose...
f anyone has a meto carb or small intercooler let me knw please
PostPosted: Thu Jan 27, 2005 5:21 pm
yeah i think the hard bits to get are the carb and plenum chamber
