It is currently Mon Jul 28, 2025 2:02 pm
 Post subject: Temperature switch
PostPosted: Mon May 26, 2008 9:00 pm
Forum Graffiti
I'm wondering where I can get a temperature switch for my thermo-fan? Are they available and where do you get them?
Oh and where would be the best place to put it?
Cheers :)
Sam
PostPosted: Mon May 26, 2008 9:10 pm
I have a factory fitted one on my Rover and the switch is in the bottom radiator hose, get onto Steve at Brickworx and see if he has any floating around.
Cheers Pete
PostPosted: Mon May 26, 2008 9:37 pm
Maybe try Ashdown
http://www.ashdown.com.au/catalogues.asp
Also worth putting in a relay if you don't already have one :wink:
PostPosted: Mon May 26, 2008 9:44 pm
Forum Graffiti
Sorry, where would I put the relay? I hate electrics... :P
PostPosted: Mon May 26, 2008 9:49 pm
http://www.jaycar.com.au/productView.as ... BCATID=347
PostPosted: Mon May 26, 2008 10:04 pm
You would put it between the thermo switch and the fan. Instead of the thermo switch carrying all the load (and possibly burning out) it just switches the relay (that then provides the fan with it's power). The relay is a much beefier switch and can cope with the load much better.
They usually come with a wiring diagram and aren't very hard to wire up.
Also very good on headlights (high and low beam). Ashdowns have a nice twin relay for the high and low beams (good way to make your headlights brighter due to less current loss)
PostPosted: Mon May 26, 2008 10:06 pm
Forum Graffiti
Awesome, thanks for the explanation! :D
PostPosted: Wed Jun 04, 2008 8:30 pm
simon k wrote:
http://www.jaycar.com.au/productView.asp?ID=KC5381&CATID=25&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=347
I used one of those for a while.It does work reasonably well but once you put it in a protective box it became a little too bulky for my liking.I'm back to using a simple on/off switch arrangement via a relay for now.
