It is currently Thu Jun 26, 2025 8:54 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sun May 04, 2008 9:24 pm
Mini Mad wrote:
The TAROX
I also don't like this part:
"THE WELDING AND FITTING OF THESE KITS MUST BE COMPLETED BY A COMPETENT PERSON" :shock:
lol... referring to this bit:
A set of gusset plates which will have to be welded to the subframe.
they'd be bracing plates for the tie bars.... I guess they expect the brakes to work so well that they rip the tie bar mounts apart
PostPosted: Mon May 05, 2008 12:17 pm
Its not a bad idea really, considering that the mounting points were originally designed for single leading shoe drums and skinny creoss ply tires :shock: Its basically all that is stopping the hubs from rotating with the wheel.
- or has there been strengthening up grades to the subframes since the early days? :?
-James.
Toyota 4EFTE Powered Minivan.
