It is currently Thu Jul 10, 2025 3:07 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
 Post subject: Ryco Cartridge Filter
PostPosted: Sat May 03, 2008 2:18 pm
Been a while since i bought one of these. Grabbed the only Ryco R2200P i could find in Cairns from Rape and Co.
I remember them being wrapped in plastic inside the box. This one wasnt and only came with the big round thin seal for around the top of the canister? They used to also have 2 other seals with them as well.
Is this how they supply them now or has someone nicked the 2 seals? The plastic bag that the big round thin seal came in is unopened.
PostPosted: Sat May 03, 2008 2:48 pm
Just found another 2 at Ricebarn and they are exactly the same.... Not sealed in plastic and missing the 2 seals... So Ryco see fit to up the price on the filters and also remove 2 seals from the kit... Smart marketing.
PostPosted: Sat May 03, 2008 2:58 pm
I've just started buying those again, I bought one 3 weeks ago, and it had the 2 little seals as well as the big one, then bought another last week and it was as you've found
PostPosted: Sat May 03, 2008 3:13 pm
Ive noticed the box is of a newer design. Made in Thailand aah saw.
PostPosted: Sat May 03, 2008 6:02 pm
We should complain to Ryco. :x
PostPosted: Sat May 03, 2008 7:21 pm
Ive sent them an email to "please explain".
PostPosted: Sat May 03, 2008 7:23 pm
They're just up the road from me on the way into the city. I don't think it would raise an eyebrow however if I started a one man protest outside the factory...
PostPosted: Sat May 03, 2008 7:25 pm
Maybe we need to find those shirtless cabbies from Melbourne?
PostPosted: Sat May 03, 2008 7:26 pm
A NAKED one man protest might raise some eyebrows...but I don't know if I'm that passionate yet...
PostPosted: Sat May 03, 2008 7:29 pm
U will be when its your turn to do an oil change. Ill send this filter down to you, and you can hang it off your .....
PostPosted: Mon May 19, 2008 10:08 am
Finally got a reply from RYCO in regards to these filters. Hopefully it gets sorted out and they start selling them with the other 2 seals.
Hi Brad,
Appologies for the delay in responding, we have found that the 2 gaskets have been omitted, as you have advised.
Please accept our sincere appologies, we will have this problem rectified.
Regards,
Michael Roussety
Ryco Customer Service
GUD AUTOMOTIVE PTY LTD
245 Sunshine Road
TOTTENHAM VIC 3012
Ph: 1800 804 541
Fax: 03 9243 3366
Email: [email protected]
Website: www.rycofilters.com.au
PostPosted: Mon May 19, 2008 1:56 pm
well done!
I bought another one last week... and sure enough, only the big gasket
PostPosted: Mon May 19, 2008 2:03 pm
Id say it may take a while until we actually see the corrected filters in the shops though.......
PostPosted: Mon May 19, 2008 2:10 pm
Whilst your at it, could you please complain to Crosland in the UK - they have also started selling the other type of cartridge filter sans the seals for the bolt at the bottom. Very annoying. That's why I run a spin-on filter. There is less to omit. :wink:
PostPosted: Mon May 19, 2008 3:09 pm
I cant find an email address or website for em?
