It is currently Thu Jun 26, 2025 12:35 am
PostPosted: Fri Apr 25, 2008 11:44 am
would this work? its just its a possibility if i could work and it would be the tits if it worked?
thanks bill
PostPosted: Fri Apr 25, 2008 1:32 pm
It's been done a few times before but the main thing is it's an old motor design and it's heavy compared to the likes of a 4efte etc . Another thing is I don't think you are legally able to use a motor older than the car you're putting it in so you'd have to be careful that your mini is older than your donor 1800 .
PostPosted: Fri Apr 25, 2008 1:42 pm
thats awsum, and how about modifications to the subframe, and moving of items around the engine bay? is there much to do??
bill
PostPosted: Fri Apr 25, 2008 1:47 pm
It's the same as any engine conversion in a mini , you need to modify the subframe and driveshafts amongst other things . It's not easier just because it's a loarger version of the original if that's what you were thinking ?
PostPosted: Fri Apr 25, 2008 4:48 pm
Those B series things are boat anchors, much heavier than an A series.
HP even when modified is nothing to write home about.
There are better, newer, lighter engines around that go much harder and are smaller to fit. :wink:
PostPosted: Fri Apr 25, 2008 8:00 pm
thanks , you guys just talked me out of that idea.
PostPosted: Fri Apr 25, 2008 9:56 pm
I'm sure I've seen a Mini in miniworld years ago that had a 1700 (ish) cc 'O' series motor in it. I think we only got them here in the Morris 1500. That would be an easier conversion cause the Morris engine bay is a similar size and shape to the Mini and the engine is still over the box.
All the above reasons NOT to do it still apply though.
Madmorrie
