It is currently Wed Jun 25, 2025 11:55 pm
PostPosted: Thu Jan 20, 2005 9:01 pm
What do HIF44 throttle linkage look like? About to buy a manifold and air filter for my HIF44 and was after some pix of the throttle linage, Anyone got some? I'll be searching the UK mini parts sites for pix...
PostPosted: Thu Jan 20, 2005 9:03 pm
Ok by the looks of this, it seems to be built in? Correct?
PostPosted: Thu Jan 20, 2005 9:05 pm
No idea... but how NICE does that look! :shock: 8)
PostPosted: Thu Jan 20, 2005 9:06 pm
bling.
PostPosted: Thu Jan 20, 2005 9:07 pm
Nup, I was wrong, thats the choke... needs a linkage... so still after pix!
PostPosted: Thu Jan 20, 2005 9:11 pm
Looks in the picture to have a non adjustable cable....
be careful of hif carbs.... some accelerator cables pull fom underneath and some from on top
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu Jan 20, 2005 9:47 pm
Here is my HIF44. The throttle is to be pulled from the top.
http://www.australianbilliards.com.au/m ... _hif44.jpg
PostPosted: Thu Jan 20, 2005 10:02 pm
Many thanks to Zizzle who took some pix for me!
http://www.slabathon.com/~matt/monster_truck/hif44/
Thats exactally what I need for my carbie. Anyone got one? Oh... need an inlet manifold, too!
PostPosted: Fri Jan 21, 2005 7:25 am
pooee"http://www.slabathon.com/~matt/monster_truck/hif44/ [/quote]
with that linkage, the cable wraps around underneath the curved part at the front/below the butterfly, and is secured by the bolt thingy with the screw going into it - if that's the carb you're getting, with those linkages (throttle & choke) on it, you don't need anything else
if you get desperate, you can use a single 1 1/5" manifold, just needs to be opened up a bit, only uses 2 of the bolt holes, or you could get a bit of aluminuim and make yourself an adapter plate
PostPosted: Fri Jan 21, 2005 7:50 am
You will need a throtle bracket as well. This holds the throttle cable, original type airfilter box and is a heat shield. You will also need the part that the outer throttle cable fits into and a carb spacer. You can see all these in the last picture you posted. I got a throttle bracket from Northern Mini Parts. You may need to modify the bracket slightly depending on how thick a carb spacer you can fit.
Kris
PostPosted: Fri Jan 21, 2005 8:42 am
Looks like you got all the info Me to slow and that looks just like mine but I now have a HF piston and spring instead of the HIF Bearing Dash Pot as it was going up to fast and giving me a flat spot.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Jan 21, 2005 9:46 am
You can control that with thicker oil, cant you?
PostPosted: Fri Jan 21, 2005 11:57 am
yeah but never worked for me as i went up to a 60 grade with no luck.
But I did not try a heavier spring as local supplier did not have one at the time so it got the hs type and stuck that on and all sweet.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Jan 21, 2005 2:40 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
my hif had a little bracket like the one in the picture
makka
PostPosted: Fri Jan 21, 2005 6:34 pm
Still does Makka :D
Who's MadMax?
Users browsing this forum: No registered users and 25 guests
