It is currently Fri Jun 27, 2025 10:59 am
 Post subject: Seats & Seatbelts
PostPosted: Sun May 09, 2004 12:12 pm
Can anyone point me in the direction of regulations for updated seats and seatbelts for a Mini..?? I wanted to upgrade mine to seats out of a 1996 Daihatsu Charade (they are suitably small enough to still let you see out the back of the car) and retractable seat belts. Is this something that permittably you can do yourself or is it a NSW RTA Regulated "Authorised fitter" only sort of job..?? :?
PostPosted: Sun May 09, 2004 1:35 pm
I put 2 `Klippan' K1512 retractable belts in the front of my `70 Mini.
Listed for Mini- all models.
Only problem was the reel mounting plate was a bit long, so I drilled another hole in it.
As long as you use the original mount points there should be no worries.
re the legality of seat mounts- I'm not sure. I made some to fit Alfa seats to the original Mini brackets, I had no problem getting rego pink slips for the last 6 years. :wink:
 Post subject: seats
PostPosted: Sun May 09, 2004 4:35 pm
I agree with dr mini
ive got areotec seats in my mini mounted to frames i got from revo race gear....as long as you use the standard mounting hole it will be fine remember to use high tensol bolts tho not steel ones....
PostPosted: Sun May 09, 2004 5:07 pm
I've now mounted a Cobra Trophy seat onto another subframe using the original Mini mount brackets. Bolts are all hi-tensile Unbrako cap screws. It's way more rigid that the Alfa ones were, so I don't expect any problem. 8)
PostPosted: Sun May 09, 2004 5:25 pm
yeh , your sub frame looks better than the after market 1s aswell :wink:
lookin for another clubby
PostPosted: Sun May 23, 2004 12:46 pm
Hi
I also went the Klippan way in my 1967 deluxe.
K1512 wuth 300mm stalks for the front. No probs fitting myself. I didn't redrill the steel extension, just layed it forward to clear the doors. :wink:
Also put retratables in the back for the kids part no K2256, which are horizonal mount, work similar to the clubbie belts, from the centre and clip on to the side. Just needed to shorten up the buckles a bit and turn around the mounting so they were straight. Work a treat. Also had to drill a few holes.
To look really good, get reel covers part no 11993. :) :D
DOT was no probs.
If you want better instructs on the rear belts, email me.
Craig
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Sun May 23, 2004 4:20 pm
how much do these Klippan seatbelt cost and where would you get them from?
thanks, cazmo
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Sun May 23, 2004 5:24 pm
Available from Robbos Spares or most of the others, if they don't have they can get.
I think you can buy online too from Klippan, try a Google search. 8)
PostPosted: Sun May 23, 2004 8:30 pm
thanks, cazmo
I got mine from Repco......... how easy is that!!!
Retail each front belt $110.99
each rear belt $122.99
covers for the rear reals $10.99
That was 12 months ago
Cheap if they save your life :wink:
Ring around the auto stores, your sure to get them cheaper, I did.
Craig
PostPosted: Mon Sep 10, 2012 10:35 am
sorry for the thread revival
Does anyone have any issues with:
a: the door pockets hitting the retractors?
b: the retractors not releasing the belts unless on a perfectly flat surface?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Sep 10, 2012 11:12 am
I had no problems with mine Ryan. If I remember I'll take a pic tonite and check what model I used.
The only problem I had was that sometimes when the door got closed the door pocket would "tug" the belt and cause it to lock. Over time they have become less sensitive to this happening. Drivers side never does it now.
They are ok as far as not locking on slopes and the klippan ones I have don't hit the door.
PostPosted: Mon Sep 10, 2012 10:29 pm
Klippan retractors, I originally bought them from MiniKing a couple of years ago.
I think would be this one with a tunnel mount stalk. Not sure what belt length though. Probably Short or standard.
http://www.selectgear.com.au/admin/uplo ... H_BELT.pdf
Door pocket clears no problem. Note reel can be angled back slightly so webbing lines up properly with b pillar mount.
PostPosted: Tue Sep 11, 2012 7:37 am
I've got the same as Phillb above. These work no dramas, and don't foul the door pocket. I also found it necessary to bend The black metal bracket the belt runs away from th door to help it clear.
PostPosted: Tue Oct 09, 2012 6:33 pm
i also have the same in my 71 Clubman, i mounted thenm the same as the photo just with the bracket horizontal. i found the Tombstone seat were a bit wide though...
1971 Mini Clubman 1100
1968 Morris Mini Deluxe 998
http://www.facebook.com/geelongminiclub
"Everybody should drive a Mini, everybody should own a Mini at some point, or you are incomplete as a human being." -James May, about the classic Mini.
PostPosted: Wed Oct 10, 2012 3:26 pm
I got a pair of new front belts made by Hemco in Victoria $174 delivered available in a range of colours, took about 10 days, fabulous.
