It is currently Wed Jun 25, 2025 12:32 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: upgrading the G13B
PostPosted: Thu Apr 03, 2008 4:55 pm
HI
Just wanna know if I replace my G13B Mk1 components in my Mini with
1)adjustable cam gears,
2) a larger coil kit, and
3)a larger (45mm - the maximum) throttle body from the 30mm stock ones.
Could they really improve things much/a lot and also will they have any drawbacks such as shortening the lifespan of the engine, impacting timing and the electircs, etc? And also which of these (1-3) would have a more noticeable improvement in comparison - so that you will definately do first.
I am unsure to how they can replace the cam gears given the extreme tight space in the engine bay. :shock:
Thanks.
1964 Morris Mini 850 - G13b gti powered - classic yet practical
1968 Morris Minimatic - 1100cc - classic & breakable
Sun Certified Java Programmer v5 310-055
 Post subject: Re: upgrading the G13B
PostPosted: Thu Apr 03, 2008 5:23 pm
Forum Graffiti
Ben_Aus_Mini wrote:
HI
Thanks.
1) If you're looking for bang for buck cam gears with stock cams are more of a bling thing.
2) Larger coil kit? I presume that means the G13 runs a dizzy and coil? I think you'd be better off saving the money and putting it towards an electronic ignition setup like MegaJolt/Squirt.
3) Throttle body would be a nice upgrade, not sure how far you could go on the stock ecu though...
If it was me, I'd be saving up for a programmable ECU ( if you don't already have one? ) Go the exhaust/intake route first, elec ignition, bigger throttle body, cams, cam gears, etc. That should make a nice lil suzi 8)
I can't imagine any of those things hurting the lifespan of your engine, unless of course it's tuned incorrectly or you raise the rev limit.
PostPosted: Thu Apr 03, 2008 5:34 pm
Forum Graffiti
Ok so I checked out your thread you've got going on, damn nice car! 8) Hopefully mine turns out something along those lines :)
So it looks like you've got the intake and exhaust all sorted... Next thing I'd suggest is the electronic ignition. After that it's all about getting more air in -- so you could upgrade the throttle body, or depending how hardcore you want to get, go quad throttles/ITB's. Then it's just whack the biggest cams in you can handle and tune... Depending on your cams and rev limit, your injectors may need upgrading too.
That's the general formula for an N/A engine :wink:
Of course if you went forced induction that's a whole other kettle... :twisted:
PostPosted: Thu Apr 03, 2008 6:17 pm
id go with the larger throttle body first off and maybe bigger injectors next.. shop around for one of those "performance chips" if they make them for g13b's. if they do than you could probably buy a cam/chip/ and valve spring package
Mearcat wrote:
PostPosted: Thu Apr 03, 2008 7:04 pm
Hi Ben
I would suggest fitting a EMS like a adaptronic ecu, a Sr20 throttle body conversion and a set of BD14 cams as they are mild enough for the street but gives a nice kick between 3500-8000rpm :lol: .
you can also visit redlinegti.com its a GTi forum heaps of info on modding NA's.
wayne
PostPosted: Thu Apr 03, 2008 7:14 pm
Looks to me like you have a Mk 1 Gti engine, so "chipping" your ECU is out of the question.
1. Good gains can be had with the adjustable cam gears. You will need some dyno time too though.
2. Unless you are having ignition problems, a larger coil pack will be a waste. Save up for a MS (will give you many more tuning options too)
3. The SR20 throttle body is the best bang for buck mod. Will not increase power, but will allow increase responsiveness.
http://www.redlinegti.com/ is the place to search. The stock ECU does not manage timing on the Mk 1, only fuel. Stock injectors should be fine with the above upgrades & can be forced to deliver a little extra fuel with an adjustable Fuel Pressure Regulator (not rising rate FPR).
<Wayne beat me to it>
PostPosted: Thu Apr 03, 2008 8:38 pm
Try here:
http://www.suzitech.com/
PostPosted: Fri Apr 04, 2008 5:46 pm
geez those cams arent cheap! $1150 a pair !
id say just get a bigger MAF sensor and throttle body
Mearcat wrote:
PostPosted: Fri Apr 04, 2008 5:48 pm
Forum Graffiti
It's because they're new billets. You could get them reground a lot cheaper.
PostPosted: Fri Apr 04, 2008 7:33 pm
... plus if you get them reground you will still have the hollow camshafts of the Mk 1s. Still not cheap though.
PostPosted: Fri Apr 04, 2008 9:19 pm
Turbo......... 8)
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Fri Apr 04, 2008 9:25 pm
Forum Graffiti
'77 clubby van wrote:
Turbo......... 8)
If you're after heaps of power I'd go turbo too.
After you start going custom cams, etc it would work out cheaper to go turbo and have more power to boot..
PostPosted: Fri Apr 04, 2008 10:10 pm
isnt a billet like a chunk of alluminum groung into something slid? wouldn't that melt?
Mearcat wrote:
PostPosted: Sat Apr 05, 2008 9:54 pm
Billet is usually referred to as blank of steel or aluminium that is a section of metal used for rolling into bars, rods and sections. It can be a product of the ingot route, or increasingly today produced directly by continuous casting.
Billets are then ground or machined into new shapes!
PostPosted: Sun Apr 06, 2008 1:38 pm
archangel thats a great site i may have to get some bling for my suzuki mnnn i am suprised that theres still that much available off the shelf for the gti
