It is currently Thu Jul 10, 2025 1:47 pm
 Post subject: A+ rocker gear
PostPosted: Thu Mar 06, 2008 10:11 pm
Just a technical point I want to sort out. Can you use the rocker gear from an A series head in conjunction with an A+ cylinder head ? meaning are they interchangeable or do you specifically have to use A+ with A+?
TasTyger :?
PostPosted: Thu Mar 06, 2008 10:12 pm
Yes, they'll come over fine.
PostPosted: Fri Mar 07, 2008 9:46 am
Yes you can- forged, pressed steel, and sintered A+ are all interchangeable, on either an A or A+ head.
Lift ratios I measured recently (with RE13 cam):
Forged Cooper S 1.16:1
Sintered A+ 1.18:1
Pressed steel (850/998/1098) 1.21:1.
All these were measured on the same rocker posts and with a new HD rocker shaft.
Note if fitting smallbore rockers to a 1275 you usually have to put a flat washer next to the exhaust rockers, to align them better to the (offset) valves.
<edit> typo
Last edited by drmini in aust on Tue Mar 11, 2008 8:57 am, edited 1 time in total.
PostPosted: Tue Mar 11, 2008 8:31 am
yep go for the pressed steel babys give better lift than A+ and are stronger :wink:
PostPosted: Wed Mar 12, 2008 3:41 pm
After I've offset bushed them .044" they are 1.31:1 ratio. 8)
<edit> here's a pic-
Last edited by drmini in aust on Thu Mar 27, 2008 9:12 pm, edited 1 time in total.
PostPosted: Tue Mar 25, 2008 6:56 pm
Yep,
I put my 1.5:1 minisport ones from my 998 A series to my A+ 1275. :-)
My 2 cents
