It is currently Wed Jul 09, 2025 4:04 am
PostPosted: Fri Dec 28, 2007 1:39 am
hey
just wondering if theres any preferred head gasket types out there>?
would it be wise to increase the torque setting on the head bolts.. or not needed??
or would stretch the bolts n cause greif?
my mini suffered the bhg disease :(
booooost didn't help :(
bigger radiator on its way......
thanks
lucas
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Fri Dec 28, 2007 1:43 am
what size donk?
PostPosted: Fri Dec 28, 2007 7:45 am
If you have head bolts, and are taking the head off, bin the bolts.
Get some good quality head STUDS instead.
No more Minis!......For now.
PostPosted: Fri Dec 28, 2007 10:04 am
I would also agree with replacing Bolts to Studs..plus your not sure how many times they have already been torqued down before and could break (and this can be a rite pain in the arse) Trust me
PostPosted: Sat Dec 29, 2007 6:06 am
re the original question- head gasket types.
IMO the best ones available here now are the ACL Monotorque- p/no CP250MT is VRS set (850-998-1098), and the Payen BK450 (1275).
I'd forget the so-called `copper' ones, they have nothing inside them since they got rid of the asbestos years ago (before that, they were good).
My 2c, :wink:
 Post subject: re: best head gasket
PostPosted: Thu Feb 14, 2008 8:04 am
Payen BK450 (1275) aka the BLACK METRO TURBO HEAD GASKET is the one most high-end A-series engines use. Will cost you $22 from karcraft (as quoted from last month).
I think those copper ones are overrated.
 Post subject: Re: re: best head gasket
PostPosted: Thu Feb 14, 2008 8:24 am
the BK450 is called MPi gasket over here as it was the first engine with this type of gasket. its the best i've ever used but its not related to turbo or something, the turbo used to use the same gasket as the NA engines
Rover 214 atm ....
PostPosted: Thu Feb 14, 2008 8:41 pm
You can get a triple layered stainless steel head gasket...For $230.00...Which is a bit out of my depth for a gasket...I use the black turbo ones.
PostPosted: Thu Feb 14, 2008 11:47 pm
I'm Bert , where's Ernie
whilst we're on topic, supercheap sell the acl gaskets, if anyones interested drop me a pm.
but, as said above, forget the copper ones.
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Fri Feb 15, 2008 9:04 am
the black monotorque one :D about 40 bucks for a VRS kit, so you get all the bonus gaskets you will need (maifold, thermostat housing...) you also get o rings for valves but they are useless you need top hat seals.
you get the torque settings with the kit, but i think its 25lb/ft, then 30, then 40??? its importnat to do it in the right order, so your head goes down straight. directions are on the packet :D
retorque after driving, to be sure
78 Leyland Mini - Prince
PostPosted: Fri Feb 15, 2008 9:11 am
This is the ACL one I mentioned above, ACL Monotorque.
For 850-998-1098. NOT 1275.
 Post subject: mm1275
PostPosted: Fri Mar 07, 2008 3:03 pm
The bolts actually have more thread, and protrude into the block further sometimes good if your block has been striped. pros and cons for each.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Fri Mar 07, 2008 6:36 pm
Sorry when this happens to you
PostPosted: Fri Mar 07, 2008 6:45 pm
These bolts (only used on Oz motors BTW) are all over 35 years old now. If you MUST use bolts, go buy some new Grade 8 ones.
I flung all mine, went to studs. No more problems. 8)
PostPosted: Fri Mar 07, 2008 7:45 pm
ditto
