You can get it all from MiniSpares, that's the cheapest. Ditto the valve springs (use Cooper S ones). Or buy from Karcraft- not much dearer.
I usually use 1275 valves in 202 heads. I machine the intakes down to 31mm, and the exhausts to 27mm. You can fit unleaded exhaust seats with these valves, just machine the new seats out to 24.5mm before you fit them.
Yes these valves are a little longer. I use 1275 bronze guides but leave them 2.0mm higher, fit a 12mm flat washer under the springs, and pack the rocker posts up 2.0mm (unless it's a BIG cam)
If you want to avoid all this work, use new 998 Cooper inlets and oversize exhausts, see below.
Karcraft prices:
valves: Cooper inlet 1.219" $16.64 ea, exhausts 1.062" $14.69 ea
valve springs 7000 rpm $95.62/set
valve guides bronze $74.80/set
valve caps & collets- buy some s/h ones- plenty about.
<edit> bare heads are good- easier to check for cracks, wear etc.
Anyway the old valves & springs would be probably ****.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
