It is currently Thu Jun 26, 2025 8:42 am
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32, 33, 34 ... 125  Next
PostPosted: Wed Dec 05, 2007 10:47 pm
Yep, its big, bigger than the standard Mini unit.
PostPosted: Thu Dec 06, 2007 9:53 am
I got an email back from Aussie Desert Cooler wrt teh Hotbox :
"The enclosing box is a 7 inch cube. The fan is up flush against the heater core and the inlet / outlet pipes suit standard heater hose."
-Alan
PostPosted: Thu Dec 06, 2007 10:02 am
you guys ought to stop using clubmans (or imported roundnose pommy shells built after 1971 - is that better Josh?).... use a pre ADR car and you don't need a heater/demister at all!
:P
PostPosted: Thu Dec 06, 2007 10:10 am
simon k wrote:
you guys ought to stop using clubmans.... use a pre ADR car and you don't need a heater/demister at all!
:P
Don't know about you, but I'd prefer to be able to see out of the windscreen on a cold morning and drive in warmth on a cold day/night. :D
-Alan
PostPosted: Thu Dec 06, 2007 10:36 am
/diversion of clubby bashing..
I got an email from Stuckeys regarding SP9000's too:
Good morning Josh.
The SP9000 is no longer available unfortunately.
PostPosted: Thu Dec 06, 2007 12:18 pm
Mearcat wrote:
:P
pfft, both way overrated!
PostPosted: Thu Dec 06, 2007 12:56 pm
This space for rent
Driving home late on a freezing, wet winter's night with the driver's window open so you can see is just part of the Mini experience..
PostPosted: Thu Dec 06, 2007 1:09 pm
So you can see, so you can dilute the CO fumes.. either way :lol:
Gareth.
PostPosted: Thu Dec 06, 2007 3:58 pm
Good morning Josh.
Fark!! :shock:
Does that mean no longer imported, or no longer manufactured. Can you give Russell a call and ask him?
PostPosted: Fri Dec 07, 2007 7:12 pm
Josh,
Just sent a quick email to a guy I have corresponded with at DOTARS with regards to ADR 15 which has to do with the heater/demister and was it applicable on our modified vehicles.
The reply..................
Dear Mr Treloar.
Yes the demister is still required. See ADR 42/04 Clause 23 http://www.infrastructure.gov.au/roads/motor/design/adr_online.aspx
Regards
Ross Pettersson
Which of course we knew, but just needed it confirmed. So, onward and upward
Tricky
PostPosted: Sat Dec 15, 2007 3:47 pm
any updates tricky.
Cheers Dan
PostPosted: Sat Dec 15, 2007 6:56 pm
Only on Barbie........ :(
PostPosted: Sat Dec 15, 2007 8:37 pm
i was talking to Will on thursday about your car he was telling me that he is only pulling the mold does this mean your doing the rest of the body work your self.
Cheers Dan
PostPosted: Sat Dec 15, 2007 10:17 pm
No mate, none of the bodywork, that's still to be done by the spray painter/panel beater.
Will and I are just fitting the body kit to the car.
PostPosted: Mon Dec 17, 2007 5:49 pm
ok then who are you getting to do the body work then.
dan
Cheers Dan
