It is currently Tue Jul 01, 2025 10:28 am
 Post subject: Rover injected 1.3
PostPosted: Sat Dec 08, 2007 3:35 pm
Hey Guys,
I have a Mini Clubman (78')
I have been offered a 1.3L Rover Injected motor, not sure if its spi or mpi. I'm just wondering if it is a worth-wile conversion over a carby 1275cc. because its looking like one or the other. I doubt i can afford a starlet conversion or the like at this stage.
i figured that the rover motor may be a better option as i believe they are a later build (am i correct?) and therefore more likely to be in good condition.
would this sort of conversion be "bolt in" or would i still need a different subframe ect..?
Any advice would be appreciated.
Matt
PostPosted: Sat Dec 08, 2007 4:36 pm
If it's fuel injected you'll need an efi fuel tank. Yes it should bolt straight in. Have you got disc breaks, you'll need them for a legeal roadworthy :wink:
PostPosted: Sat Dec 08, 2007 6:38 pm
yeah, fuel tank included
PostPosted: Sat Dec 08, 2007 7:36 pm
Bolt in one would think!
PostPosted: Sat Dec 08, 2007 7:41 pm
MPI SPI get ride of it and go Carb..Same otherwise its the same..yepo make sure you have a disc set up thou
PostPosted: Sun Dec 09, 2007 5:11 pm
what sort of power do these engines produce?
PostPosted: Sun Dec 09, 2007 5:54 pm
SPI was poor, MPI not much better.... :lol:
around 61-63HP from memory.
PostPosted: Sun Dec 09, 2007 6:26 pm
SPi: 53 (3.1:1 FD) and 63HP (3.2:1 FD)
MPi: 63HP only (2.76:1 FD)
sadly not all engines are in good condition, just opened a 53 SPi engine and gearbox and its not realy worth to rebuild it
Rover 214 atm ....
