It is currently Tue Jul 08, 2025 6:02 pm
Post new topic Reply to topic  [ 103 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
PostPosted: Thu Dec 06, 2007 12:16 pm
so you think grinding only on the casing. I have ground a fair amount off & wondering if i am going to have a hole soon
PostPosted: Thu Dec 06, 2007 12:48 pm
Online
In my case the problem was the 3mm extra stroke & Chevy big end nuts, these are plain hexagonal and a little bit taller than S nyloc ones. But they miss the Mini-K 4 synchro case with no mods needed.
If you do grind through, it's not the end of the world- I once cut 4 holes in the front of an early 850 case so my 1275 crank with big journal rods would swing. :lol:
Just TIG weld some sheet on if you have to, but a standard stroke 1275 should be made to swing without going through a 22G68 casing.
PostPosted: Thu Dec 06, 2007 2:55 pm
not araldite???
PostPosted: Thu Dec 06, 2007 4:11 pm
Online
not araldite???
Well... 30 years ago I cast new lumps on using araldite and masking tape, these days a MIG or TIG is the go.
This one of GR's has the latter. 8)
PostPosted: Thu Dec 06, 2007 7:31 pm
I am wondering about the breather on the fuel pump hole. The addition of a tube on the inside of the hole aimed in a different direction may be a solution. You don't need to have the breather right next to the cam you could aim it anywhere.
A motor on a dyno would be a good place to test it. :wink:
PostPosted: Thu Dec 06, 2007 7:44 pm
Online
I reckon design it with a baffle on end of tube inside the block, that lets the oilz drip off.
Mine was just an S breather canister welded to a flange... as I said, was a waste of time.
PostPosted: Thu Dec 06, 2007 8:16 pm
Yeah, a baffle plate over the hole or something to just stop the direct stream of oil going into the breather.
A mate had a 186 motor in a Sports Sedan that had a con-rod let go and it punched a nice hole in the side of the block. So he cleaned up the hole and pressed in a bit of pipe, instant breather!
PostPosted: Sat Dec 08, 2007 6:20 pm
And? What were the results. didn't make it as we added a few mini's to the family
PostPosted: Sat Dec 08, 2007 6:38 pm
Yes I want to know also..and Aaro Spil the beans
:shock:
PostPosted: Sat Dec 08, 2007 7:47 pm
Online
Full results are now up in cruises and events, see http://www.ausmini.com/forums/viewtopic.php?t=37989
dyno sheet-
:wink:
PostPosted: Mon Dec 10, 2007 9:57 am
congrats on the great result
Would have been a fun day.
How much running/bedding in did you do other than the 15 min to bed in the cam prior to the power testing
PostPosted: Mon Dec 10, 2007 11:44 am
Good results - looks like the SU wins :roll: 8)
David L
PostPosted: Mon Dec 10, 2007 2:44 pm
Online
On Saturday morning we ran it in at varying loads and rpm for 30 or 40 mins.
Then we retightened the head, readjusted the rockers to .020", and did the power runs. :wink:
During the power runs we tried closing the rockers up to .016", and it immediately lost 7 ft/lb of torque at 5,500 and 6000 rpm... :shock:
Note these are not stock rockers though, they are Corollas- 1.46:1. :wink:
PostPosted: Tue Dec 11, 2007 6:51 am
.004" made that much difference!
Just goes to show how important the valve clearance is.
Have to remember not to be tempted to close it up to quieten it up.
what effect did it have at the lower rpm range?
PostPosted: Tue Dec 11, 2007 4:58 pm
Online
At 4500 it had lost 5 ft/lb, at 5000 had lost 7 ft/lb.
I was going to try them at .018" too, but got sidetracked... :lol:
