It is currently Tue Jul 08, 2025 11:28 pm
 Post subject: SU question
PostPosted: Tue Dec 04, 2007 7:57 pm
Just a quick question, if su's work under vacume will they still work normally if set-up as a blow-through forced induction? I have seen suck though set-ups, but can they work with an intercooler, or will the intercooler mess about with the fuel/ air mixture or anything?
Thanks!
PostPosted: Tue Dec 04, 2007 8:18 pm
There are blow through set ups used from the factory on Metro Turbo engines. These can be found and no further mods are required to use them.
I think normal SU's can be modified to run with boost at a cost.
PostPosted: Tue Dec 04, 2007 8:27 pm
yeah Im in the process of getting one of a metro turbo from the UK. Is it the HIF6 or the HIF44 off a metro turbo? and do you know if n/a metros used the same carb as the turbo ones?
PostPosted: Tue Dec 04, 2007 8:52 pm
The factory turbo specific SUs had sealed shafts, balanced breathing to the float bowl & linkages were on the opposite side of the carbs than the "usual" possition i believe (that may not allways be the case tho as people can "play" with that part of it quite easilly & change things around to suit "their own" application)
& yes, you can intercool it all before/prior the carb
PostPosted: Tue Dec 04, 2007 9:16 pm
Forum Graffiti
IIRC the turbo Metro's used a boost modified HIF44.
Intercooling a blow-thru setup is fine, but NOT a suck-thru setup. The fuel pools in the intercooler and you basically end up with a bomb waiting to explode ( backfire = dead :evil: ). On that note I have seen it done :shock: You wouldn't catch me near it... :?
PostPosted: Wed Dec 05, 2007 5:09 am
I have just set a blow through on a HIF44 metro turbo.
http://moke.com.au/Forum/index.php?topic=1858.0
This is a link to the moke forum with some of the latest pictures.
It's not a mini, but still a bloody lot of fun! (and keeps me poor)
PostPosted: Wed Dec 05, 2007 5:00 pm
yeah thats what I thought would happen with a suck thru-intercooled set-up, Im going for my origianl plan of a blow-through intercooled, which is good as I have all the parts already (besides my carb..) so they wont end up as dust collectors haha.
PostPosted: Tue Dec 11, 2007 4:27 am
Other suck-through issue is the vacuum in the turbo at part-throttle.
If it has no special seals, it`l draw the oil out of the bearings.
