It is currently Wed Jun 25, 2025 11:54 am
 Post subject: mini s*it its self
PostPosted: Mon May 03, 2004 10:07 pm
i was bashing round in the blue(red) ls on sunday, i was goin up a small hill at bout 25km at 1500 rpm in first, it statred to splutter then died, so i turned it round and tried a clutch start but no luck, i then changed a heap of s*hit and still wont go, no spark at all soi any ideas? i was thinking coil but dont wanna fork out $40 for a paddock basher :( thanx guys . ben
lookin for another clubby
PostPosted: Mon May 03, 2004 10:27 pm
Check the points first- probably closed up or full of crap. :lol:
PostPosted: Tue May 04, 2004 9:01 am
fuel? :D
PostPosted: Tue May 04, 2004 1:48 pm
I recon points, as well... Try the earth of the dizzy allway's comes out. "the wire that runs from the dizzy to the coil"
 Post subject: car wont start.
PostPosted: Tue May 04, 2004 3:59 pm
sounds like coil....pinch one from ya dads car....brfoure ya buy one ya self....it it works then go and buy one....
PostPosted: Tue May 04, 2004 5:58 pm
i changed the points on sunday (after it died) and the rotor button and cap aswell as ht leads , i changed the coil aswell but i think they were both crap
PostPosted: Tue May 04, 2004 7:12 pm
a couple months ago i was driving through Auburn at 12am and my engine just died without any sputtering. it was farkn scary, especially in Auburn with low cars done-up sick mate style speeding past and staring
called dad, slung rope around the iron engine cover underneath to the back of the prado and tugged back home. (the thing that pissed me off was even though my car wasnt running, the miles ticked over)
next day called Davo and Stevo, told me to check:
1) take out a lead, shove a screwdriver down it, hold onto the rubber, put the screwdriver shaft near the engine head. start engine. if it sparks then theres something wrong with the fuel system, if no sparks then something wrong with electrics
2) fuel pump if you heard sputtering. (unhook fuel hose just before carby, put a cup under and turn the car over. if fuel flows, then go to next point)
3) take carby out, blow through all channels
4) check wires. a tiny short wire from alternator to dizzy was poorly connected, vibration of car slowly worked its way apart. this fixed everything.
5) open up dizzy cap and clean white chalky shiet where the thing spins around
my engine still turned, but wouldnt fire so 4) fixed it
Inconspicuously Conspicuous
PostPosted: Tue May 04, 2004 7:20 pm
Yeah I had a similar problem. Point 4 fixed it for me. The wire was badly attached but the car was running, barely. Then as soon as I touched it it fell apart. Doh! I was pretty pissed off so I fitted electric ignition. No dramas since!
Anto.
PostPosted: Wed May 05, 2004 3:31 pm
wouldnt want to let go of that rubber part now would you!
[Maverick] 1971 Mini K
PostPosted: Wed May 05, 2004 5:28 pm
Coil leads quite happily zap you through the rubber. Found that out the hard way when compression testing a Gemini. Last time my Mini broke I tried that method for testing the spark but it was so bright I couldn't see if there was spark or not. Just stuck my finger on the lead, and yep, there is spark! Don't do it on EFI tho coz the coils on those will kill you...
PostPosted: Wed May 05, 2004 10:39 pm
god shykes
im glad my electrics screwed up or i couldve learnt a lesson the hard way
PostPosted: Wed May 05, 2004 11:01 pm
bloody oath!...id stilla void it on any car nonetheless!
PostPosted: Wed May 05, 2004 11:03 pm
If you want to pull the leads off WHILE RUNNING to see if it's firing, use a decent pair of electricians pliers. And pull on the boot, not the bloody wire- most are only carbon string inside.. :wink:
Last edited by drmini in aust on Thu May 06, 2004 7:44 pm, edited 1 time in total.
PostPosted: Thu May 06, 2004 8:48 am
Another way to test is to take the spark plug out too and ground it, sometimes that is easier (never done it that way myself though).
