It is currently Thu Jun 26, 2025 11:33 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Tue Nov 09, 2004 10:14 am
whats the height of the window hole?? and can irt be enlagged... is it a flat section that could be easilt cut open to fit the rear side window?
PostPosted: Tue Nov 09, 2004 10:22 am
bnicho wrote:
If you are talking rear windows, why not start with one of those one piece fibreglass rear doors? Then you can easily modify it as you like. 8)
cool idea (and no rust)!!! where do I get one of them????? :D
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet. :P -Tzi 4-9-04
PostPosted: Tue Nov 09, 2004 10:30 am
problem with rear (as in back door windows) is exaust fumes.. especially when stationary at lights etc
PostPosted: Tue Nov 09, 2004 10:52 am
The last one I know of came from Northern Mini Parts (pre the change of ownership). Not sure of cost?
That one was fitted to a van by a VMCI member using honda hinges at the top and a Starlet latch at the bottom to make a rear hatch. Looked good! 8)
Yes, exhaust gasses may be a problem. But a lot of holens and falcons had this arrangement so it should not be insurmmountible. Maybe a pipe that dumps downwards?
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Nov 09, 2004 11:52 am
take a look at a 90's Pathfinder, before current shape. I had one years ago. The rear glass opens up and outward, but the door stays put. When the door opens, it swings out to the right.
PostPosted: Fri Nov 12, 2004 11:37 am
well the old XC falcon wagons have a wind down window in the tail gate and the exhaust points out to the side behind the rear wheel
when it comes down to it, if the window is open you will have enough airflow anyway
my van has about 1/4 of the door seals left on one side and none on the other.. i dont get gassed out (thats what the lil vent in the top is for i guess.. haha
now any glass guy worth their two cents can cut you a window to any shape.. and as the panny van rear glass is not curved at all any glass guy will do
make youself a frame (or get a machine shop to do so if you cant, get it chromed or paint it and use the hinges and catch from a mini rear tilt out window.. i rekon even if you tint the things you should get away for less than 400 dollars
thats just my 2 cents worth
a way cooler idea is like an XC falcon wagon with a wind down window in a drop down tail gate (more expensive obviously and more engineering required for the winder, but doable.. pull the mechanism out of something like a big car coupe with no window frame (like an XP falcon).. the mechanism doesnt have to be the exact size as it doesnt reach to both sides anyway.. just need to be a bit smaller than the opening sides, slide up in rails anyway
back to your bubble idea, if you choose the first option, any place that fabs plastic could make you up some in translucent black perspex instead of the glass, expect a couple of hundred a side for just the windows though as perspex is expensive, but the process is simple. (anyone whos done plastics in highschool would be able to whip one up)
trying to get one off another car and welding in bars n crap is tacky. custom jobbys are not that much more expensive in the end and look 100% better
Expert in training
PostPosted: Thu Jan 06, 2005 10:07 pm
now THIS is what you're looking for!!!
I've been thinkin about windows for the rear too! I wanted side sliding ones.
Check out this site, these guys will be able to make what we want FOR SURE! price is another story though... :roll: but there's no harm in asking i guess! :lol:
http://www.mmw.com.au/windows.shtml
PostPosted: Tue Jan 11, 2005 12:19 pm
Go see a caravan builder.....
A friend had a flat roof van with sliding side windows that he got from a caravan builder....well, until a branch from a gum tree crushed it, that is!
72 Clubman and a 75 Van.
PostPosted: Tue Jan 11, 2005 12:30 pm
caravan builder was my first thought too.
our old XA station wagon tailgate was great, it had a wind down window, and a dual hinge mechanism so you could drop it down or swing it open to the right depending on which handle you operated.
so now i'm thinking one of those crazy scissor lift doors on the back with a wind down window in it. siiic
:lol:
michael
PostPosted: Wed Jan 12, 2005 2:19 am
I remember our '93 Ford Econovan had sliding side windows ....
But why not just make it a ute?? :roll:
PostPosted: Wed Jan 12, 2005 12:14 pm
resident alien
resident alien
What about the sunroofs that you can popup/out? Would they fit the side window area?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=50138&item=4518334127&rd=1&ssPageName=WDVW
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=33684&item=7945498685&rd=1&ssPageName=WDVW
