It is currently Sat Jun 28, 2025 2:24 am
Post new topic Reply to topic  [ 305 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 21  Next
PostPosted: Mon Nov 12, 2007 9:33 pm
even if you could buy a kit, you'd need the carb, and plenum which arent that easy to get i think..
PostPosted: Mon Nov 12, 2007 9:54 pm
ausmini mod
ausmini mod
Tell you what, if Ben decides to sell Exhaust Manifolds for Mini Turbo's thats up to him.
It took him a long time, lots of hours and work... also the dump pipe is alot more complicated than it looks in the pics.
Ill leave it up to him to tell you if he would want to make and sell them... the pipes are a work of art, seriously. I dont know if I should run them on my motor or put on my mantel :)
Pete.
PostPosted: Tue Nov 13, 2007 7:38 am
ausmini mod
ausmini mod
Hmmm, looks like there may be a slight hiccup :(
No ARP Head stud kits around... well, not that I could find. Might have to wait until they arrive in the country.
I have been promised by one supplier they have already ordered and will arrive on Thursday so ill check again then.
Otherwise, going great.
Ben will put up a couple more pictures of the new bits we got for it soon.
Peter.
PostPosted: Tue Nov 13, 2007 4:57 pm
so the steam pipe, does it already come bent?
blokeinamoke wrote:
PostPosted: Tue Nov 13, 2007 5:11 pm
so get someone to 3d model the dimensions and get it fabricated at a fabericators... :)
PostPosted: Tue Nov 13, 2007 5:29 pm
yes, just like mandrel bends. Some people call them Weld-els
Daniel
PostPosted: Tue Nov 13, 2007 7:31 pm
yep manifold is made from 25mm steam pipe , called buttweld elbows at one steel, there fairly cheap and easy to work with and come in differend sizes and angles. Probly no use for N/A but perfect for turbo as they are a medium wall (3mm) so no flex or cracking.
here's a bit of an update , enzed made the custom feed for the turbo, and the dump pipe is done , so all thats left is the intake pipe and the oil drain , should be already this weekend and if everything else is ready we can fit.
PostPosted: Tue Nov 13, 2007 10:15 pm
Yeah, this is the same stuff--->
I Had these turbo V8 manifolds made up yonks ago out of the steam pipe stuff & it really does work a treat,,, It risists cracking & warping & also soaks up the resonance involved with the harmonics & sh!t produced by the in-different pulses caused by the bang bang bang pulses eminating from the donk,,, & the wizz wizz wizz type thing happening with the turbo--> if you get my drift :-) (pretty dam technical talk i know :-) )
apparently it`s a big problem with turbo cars , especially when you have all that heat added into the picture glowing red -or - white hot as the case may be :-)
Or you can go to the time money & trouble of doing this type of thing-->
& spend a fortune with all this special stainless sh!t they use in helecopters, but at $7 per inch & the amount of time it takes to get it all perfect, why bother really,,, steam pipe is fine & does the job admirably
PostPosted: Tue Nov 13, 2007 10:40 pm
This space for rent
benjamin wrote:
How are you planning to protect the top engine mount and firewall from all the heat that exhaust is going to generate? You obviously can't use rubber in there, it'll just burn up...
PostPosted: Wed Nov 14, 2007 8:16 am
ausmini mod
ausmini mod
We are putting in heat shields.
To protect that and mainly the clutch and brake lines and the slave cylinder from boiling the fluid.
Peter
PostPosted: Wed Nov 14, 2007 8:27 am
This space for rent
Yeah, was worried about that ;) Will that be enough, or do you think you might need to get exotic with materials (i.e. ceramics)? I can imagine that engine mount is going to conduct a lot of heat to the firewall directly..
PostPosted: Wed Nov 14, 2007 8:38 am
ausmini mod
ausmini mod
We'll think of something... nothing actually planned as yet for that.
More than likely we will protect it somehow. Discussed heat shields but not in great detail.
Will update with pics, info etc...
Pete.
PostPosted: Wed Nov 14, 2007 8:58 am
This space for rent
Go the Top Gear method, and just blow a few cans of expanda-foam in there :lol: :lol:
PostPosted: Wed Nov 14, 2007 6:51 pm
kazjim ran the same turbo location in his Deluxe, he just made a heatshield for the MCs, nothing more. No probs with the steady rubbers. :wink:
PostPosted: Wed Nov 14, 2007 7:38 pm
ausmini mod
ausmini mod
Yeah, but his turbo was further away from the cylinders and his dump pipe went up and over them, mine is going smack bang along them pretty much.
Definately will put in a heat shield... or 5 hehe
Pete.
