It is currently Wed Jul 09, 2025 1:39 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Nov 11, 2007 10:16 am
Lets now add a traction control computer
Any chance you can tell us what computer your using? :)
is it part of the efi computer or a different unit?
PostPosted: Sun Nov 11, 2007 10:50 am
So Matt with one of these super doopy set ups in a Moke does it need wings to help it get off the ground or a spoiler to keep its 4 wheels firmly planted on the ground :roll: 8)
David L
PostPosted: Sun Nov 11, 2007 1:31 pm
Albino, we`re using an "Adaptronic" for this one but the "Autronic" & Motec & just about any high end after market computers will run it extreamly well.
& Hi Dave, yeah the Moke suffers quite a bit with such a big flat frontal area so it`s good to have that little extra grunt to push it through the wall of wind :-)
here`s the actual moke that it`s in--->
PostPosted: Sun Nov 11, 2007 1:55 pm
gidday matt,
didnt mean performance wise, i just have this 1426 and its going to need a bathtub head, so if i can assume a couple of grand for a 5 port, vs 3k for example for the twinky kit, then ill give it some serious thought :D
PostPosted: Sun Nov 11, 2007 3:20 pm
Jbeenz, i`d expect you "Could" get away with a big chambered 5 port for less than $2K, But i`m afraid that the twinky (even doing it cheap) would more likely end up at around $3500-$4000 mark (& upwards depending on the performance spec you`re after)
Lets see,,, ---> an 8v head at $500-ish, set of extractors at about $400-ish,,, maybe a set of bike carbs at $100-200-ish (to save money stuffing around with EFI computers & wiring & tuning & such,,, then the Twinky conversion kit at about $1800-ish,,, then all the other mods to the block face & oil filler & oil drains & engine breathers & rad braket & engine steady braket etc etc etc
It all adds up quite quickly hey?
Like i said earlier,,, if you wanted a cheapy then you just can`t go past the 5 port. Open up & pollish the chambers, angle & rough up the ports, cut seats & fit guides & crap & away you go.
The Twinky involves quite a fair bit more than just bunging it ontop... even tho my conversion kit will make it """Fairly"""" simple, it`s still not cheap by any means.
PostPosted: Fri Dec 07, 2007 5:33 am
Hey there Matt, I just thought you and any one else considering this conversion, could find this forum usefull? :wink:
http://www.efiminis.olicentral.com/index.php
