It is currently Wed Jun 25, 2025 12:01 pm
 Post subject: Drum Brakes types ?
PostPosted: Sun May 02, 2004 4:21 pm
I have two versions of wide drum brakes. One has the 1" spacer in a solid piece and the other type has 8 sections cut out between the stud holes as if to lighten it, part number 21A1279.
Anyone know the difference ?
76 1275 Leyland S
PostPosted: Sun May 02, 2004 4:35 pm
The 2nd type is Cooper S rear, the 1st type is Mini S (Clubbie).
Both do the same job- my Mini has 1 of each at the mo.
ps. there's another one too- only 19mm spacer bit- used on some Mokes... :wink:
PostPosted: Sun May 02, 2004 6:43 pm
another interesting fact is that the front shoes are WIDER than the rears, so i did a little playing round and the wider front shoes fit into the rear drums :D so is there any benefit in doing this?
lookin for another clubby
PostPosted: Sun May 02, 2004 7:39 pm
NO! :cry: :?
I've seen this tried a few times.
Unless you pack the wheel cylinders out somehow the shoes won't sit square, and they will wear crooked.
Anyhow, you don't need more braking on the back- on a damp road it's dangerous if they lock up.
Concentrate on getting your Honda discs working... :wink:
Users browsing this forum: No registered users and 39 guests
