It is currently Tue Jul 08, 2025 1:04 pm
PostPosted: Wed Oct 03, 2007 12:13 pm
you'd have to ask brickworx, im not familiar with the rover stuff, but i would think that would be okay.
PostPosted: Wed Oct 03, 2007 1:12 pm
Yep, that's a late model HS4. It would be fine on an 850 with a needle and spring change.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Oct 03, 2007 1:51 pm
Its ok sports850 has been kind enough to help me out with parts, a big thank you to sports850 for his efforts :) and thank you to everyone this has me started in the right direction.
I still need the spacer in between the carb and the manifold so if anyone has one that would be great. I've also put this up in the wanted section.
http://www.ausmini.com/forums/viewtopic.php?t=36337
PostPosted: Wed Oct 03, 2007 1:52 pm
meehal wrote:
so a carby and manifold like this would suit ok? After a rebuild and a clean....
http://cgi.ebay.com.au/Mini-Rover-1988- ... dZViewItem
cheers.
it'd be fine, but as I referred to before, if you want to run extractors with that manifold, it'd need to be cut... if you weren't concerned about extractors, then you're on a winner, might even connect up to your existing exhaust system, though would be a little asthmatic. According to Mr Vizard, you'd be looking at a H6 or an M needle without extractors.
Adding extractors to an engine will give more performance gain than adding carb - consider this, if you can't get the gases out, what's the point of trying to shove more in...
Users browsing this forum: No registered users and 27 guests
