It is currently Tue Jul 08, 2025 2:59 pm
 Post subject: ground clearance
PostPosted: Sun Sep 30, 2007 6:04 pm
I was reading the manual and it says the ground clearance should be around 6 ins Ive got about 4 it looks cool but F#&K its low what do I do to get the height back up to spec?
I live with fear everyday. but sometimes she lets me race.
PostPosted: Sun Sep 30, 2007 7:51 pm
If it's still hydro suspension, you get it pumped up by someone with a hydro pump.
I've got one- but Can-Bra is a bit far to go, check out your local Mini club. :wink:
PostPosted: Sun Sep 30, 2007 8:00 pm
and if it not hydro. replace the rubber thingos or install adjustable cones, or both. right doc.?
PostPosted: Sun Sep 30, 2007 8:21 pm
Give Ash some flowers Nick .
Translation: If you have dry suspension try replacing the rubber cones or install Hi-Lo's (or similar) or both. Your cones might be fine (I doubt it unless you have replaced them recently) and some one has cut down the trumpets thus lowering the car.
PostPosted: Sun Sep 30, 2007 8:57 pm
It's a hydro Doc. The displacers seem ok. A pump up might do the trick you think?
 Post subject: Yep
PostPosted: Sun Sep 30, 2007 9:01 pm
Yes...it could do...unless the front trumpets have punched through there cups/mountings...the club has a pump as does Melba Mtrs.
PostPosted: Sun Sep 30, 2007 9:15 pm
adjustable cones
are there really :? :o
PostPosted: Sun Sep 30, 2007 9:31 pm
buztoy wrote:
adjustable cones
He means Hi-Los. :wink:
