It is currently Wed Jul 09, 2025 9:54 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Wed Sep 26, 2007 7:47 pm
This space for rent
I've been planning this conversion for months now, and it's finally time to get stuck in 8) 8)
The car is a 1970 hydro K with a warm 1152, twin 1-1/4" SUs, BL 731 cam (I think), 12G295 head, and 3-1 extractors into a 1-3/4" stainless exhaust.
What I'm doing is ditching the spaced drum setup, in favour of a set of Mini Spares' alloy 4-spot calipers, clamping slotted 7.5" discs. This is purely a road car, but the aim is to get the car stopping really well before I start belting the thing around inner-city Melbourne traffic again.
In its current state the drums stop reasonably well, but only just after they've been adjusted after which they deteriorate pretty quickly. I hate adjusting drums all the time, hence the discs 8)
While I'm swapping hubs, CVs, etc. I figured I'd also throw a set of adjustable lower arms and caster rods on at the same time, with the intent of dialling out a bit of a geometry problem resulting from a whack in a PO's life.
When researching the conversion, I took a bit of a gamble on the Mini Spares alloy 4-pot calipers. Their documentation says they're designed to fit under most 10" alloy rims, but no specifics. I've got a set of ROH S-offset Contessa's, so I figured they'd be the most common wheel for this setup and the calipers should fit.
Hopefully.
The other gamble is that Mini Spares specifically mention that there are "clearance problems" fitting these calipers with adjustable lower arms & caster rods to hydro cars, but again they don't like to elaborate. Umm... :roll:
So, anyhoo. Enough ramble, the horde wants pics :lol: :lol:
This is a wheel. Hey, I had to start somewhere :lol:
This side of the car has about one degree of negative camber, but the other side is about 0.75° positive. Can't wait to get those arms on...
Oh, this is my home-made camber gauge. Take one piece of MDF, three screws, some fishing line, a washer and a brush up on high-school trigonometry and viola!
First cab off the rank after measuring the existing camber was to bench assemble one hub, drive flange, disc, caliper and CV, and throw the lot in a wheel and pray it will fit. This is the assembly ready for its test fit.
Man, those alloy calipers are pure sex incarnate :twisted:
I was really nervous at this point.. the whole project hinged on what happened next:
Woooooooooooooooo HOOOOOOOOOOOOOOOOO!!! It FITS!
.. but only JUST:
The outside edge of the caliper is probably only 2mm from the inside of the rim... now I'm hoping the wheels are true :lol:
So, now that there's a chance this is all going to work, it's time to get hands dirty and pull the drums off.
She's a bit road-weary...
It took only about half an hour to get from that, to this:
This is all going too well, surely? :lol:
And there we are. One fully disassembled Mini front suspension. All the ball joints split really easily.. I expected a much tougher fight.
Tomorrow we start pulling down the other side.
PostPosted: Wed Sep 26, 2007 9:38 pm
The Forkmeister
Good on ya mate, it's always good to get that start and by the looks of it should go smoothly,oop's I shouldn't have said that :wink: .Good luck with the conversion and keep the updates comming.
cheers Gerg
May the fork be with you.
PostPosted: Thu Sep 27, 2007 7:13 am
I'd love to see what's going to happen the first time you put the brakes on hard being used to drum brakes and then fitting those , that strange bouncing sensation will be your back wheels on the road .
PostPosted: Thu Sep 27, 2007 8:07 am
Congrats on giving a reasonable reason for switching to disks....none of this unqualified "they stop better" crap 8)
PostPosted: Thu Sep 27, 2007 9:50 am
Give Ash some flowers Nick .
That's starting to look really good. I think this may have to be put in the "how to" section. You're lucky with those wheels, I hope they are true!
PostPosted: Thu Sep 27, 2007 12:07 pm
This space for rent
Yeah, looking forward to that 8) 8) Gotta go get me a set of ⁵⁄₈" (IIRC) 'S' rear slave cylinders, otherwise I forsee a pirouette or two in my near future :lol:
Brief lunchtime update: The driver's side was more like I expected -- the steering rod end didn't want to split, so I had to introduce Messrs WD40 and BFH. Where there's a will...
The other hold up has been the removal of the steering arms from the drum hubs. One came off really easily, but the driver's side was seized fast and we had to bring out the grinder and take the head off one of the bolts. So now it's off to find a new HT item. Likewise, the bushes on the driver's side lower suspension arm pin were seized on solid, so the grinder got another workout.
The agenda for this afternoon is to build up the uprights, fit the CV's and wheel bearings and get some bits fitted to the car :D
-- Simon
PostPosted: Thu Sep 27, 2007 1:33 pm
this looks fantastic! and you're making it seem so easy.
some may realise that we've been looking for a decent clubby with discs for a while without a whole heap of success - if the conversion works as well as you make it seem to this may be a better option.
can I be so rude as to ask for a ball-park $ figure?
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Thu Sep 27, 2007 5:43 pm
This space for rent
I brought all the bits in direct from Mini Spares in the UK, and the breakdown was as follows:
4-pot alloy caliper disc conversion kit (includes ball joints, disc CVs, disc uprights, bearings, drive flanges, discs, pads, alloy calipers, etc): £550
Adjustable suspension kit (includes lower arms, tie rods, all bushes and rear camber/toe brackets): £86
Long-type steering track rod ends: £12
Freight (wait for it): £197 (!!!) although that's express, at your door in 4 business days.
Customs duty: Next to nothing (they calculated duty on the steering rod ends, not the whole order)
GST: 10%
.. which at today's exchange rate is a total around the $2,000 mark delivered. I'm not sure you could get the same parts locally for the same $$.. some may disagree though. Certainly the alloy 4-pot calipers are an exxy item locally, but not so direct from the UK. Take maybe three or four hundred $$ off for standard 'S' cast iron calipers and standard (i.e. non-slotted) 7.5" discs.
I'm fitting everything myself, so there's obviously no labour charge involved in getting the car on the road, aside from getting a full wheel alignment done.
Every part is brand new, so if you're looking for a disc-equipped car you should factor in around $2,000 assuming everything is in as-new condition.
-- Simon
PostPosted: Thu Sep 27, 2007 7:50 pm
This space for rent
OK, so here's tonight's update.
Work is progressing well, with few major roadblocks. The biggest problem today was getting the steering arms off the old hubs, but Mr Grinder solved that. This is what the arms looked like:
Cleaned up on the bench wire wheel:
.. and with a coat of paint:
Building up the hubs:
Seems we didn't get enough shims in the ball joint kits :x Each joint assembled dry measures about 62 thou to the hub, which means we need around 30 thou of shims, while the kit only supplies enough shims for 20-25 thou per joint. Ended up spending a bit of time pulling apart the old ball joints to rob them of shims :x
After an hour or two, this was the result -- two hubs ready to go on.
One thing we were unsure of -- the Timkin tapered bearing kit was supplied with two different oil seals. One was the type I've seen before, and the other had a concave inner surface and a lip around the face to locate a teflon "cover". Seemed these were a better fit to the drive flange than the CV, so they went on the outside. Anyone know which is right?
Before we can fit the hubs, the lower arms need to go on. These are niiiiice 8)
First on was the lower arm:
There was a small problem here -- the pin locating the lower arm has to compress the bushes in the arm in order to be tightened. When fully tight, the keyed face of the end of the pin is supposed to mate with a welded plate on the subframe in order to prevent the pin from rotating.
Problem is, I couldn't get the bushes compressed far enough to engage the pin end. Going tighter on the nut would probably compress the bushes more, but I don't think the UNF thread will take it without stripping.
Both sides are the same -- the lower arm pin key isn't engaged with the subframe. I'm guessing I'll need to re-tighten these once the suspension has a few miles under its belt and the bushes have compressed.
The tie rod presented no such challenges :)
I couldn't help myself and had to see what it's going to look like :roll:
The next job was to remove the old pot-joint boots on the drive shafts, as they were getting a bit old. My Chief Mechanic (aka Dad) took this job, and learned how not to do it :lol: :lol:
Note to self: The passenger side drive shaft is shorter than the driver's side :lol: :lol:
Much laughter later, we have two drive shafts ready to be mated to their CVs.
.. which is a job for tomorrow.
-- Simon
PostPosted: Thu Sep 27, 2007 7:59 pm
The lippy seals go on the C/V side.
The outer white plastic bit is a water/muck/salt etc excluder, Pommy cars used them.
PostPosted: Thu Sep 27, 2007 8:06 pm
This space for rent
Crap. Crap. Crap.
I really don't want to try to pull those seals out.. does it really matter if they're inside out?
PostPosted: Thu Sep 27, 2007 8:08 pm
Not really, it never rains much here- but I'd fling the plastic bit if it fouls the drive flange. :wink:
PostPosted: Thu Sep 27, 2007 8:17 pm
This space for rent
Sweeeet, there they stay then. Thanks for the tip, next time they'll go in the right way :)
PostPosted: Thu Sep 27, 2007 9:07 pm
Since u got front disc dont u need a different master cylinder? or a different diferential switch/port for the difference in braking power from drum to disc?
PostPosted: Thu Sep 27, 2007 9:13 pm
On early Minis when fitting S discs it's usual to replace the 3/4" rear wheel cylinders with the smaller 5/8" ones used on Cooper S.
If you don't, the car can lock the rears up in emergency braking. Not nice on the freeway at 110 kliks, as I found out... :!:
