It is currently Tue Jul 08, 2025 2:31 pm
 Post subject: 1970 roundnose
PostPosted: Mon Sep 17, 2007 3:16 pm
Hi. I just replaced the front suspension on my 1970 roundnose. ie:ball joints, rubber bushes, wheel bearings. It's ow making a rumbling grinding noise from the front left. It makes the noise in the straight line and with the wheel on lock. it wasn't doing this before the refit any ideas??? :(
PostPosted: Mon Sep 17, 2007 3:18 pm
Have another look at the nuts on the end of the drive shafts, if they are not torqued up correctly, this will cause the assemble to rumble.
PostPosted: Mon Sep 17, 2007 5:26 pm
pull it apart again and check everything.... it's not hard to forget something
PostPosted: Wed Sep 19, 2007 8:57 am
Hi Mick
by the nuts on the driveshaft what do you mean. I have rubber unis which I replaced.
Andy
PostPosted: Wed Sep 19, 2007 10:31 am
I think mick means the nut on the CV end, if you pulled it apart to do wheel bearings, what did you torque it back up to?
PostPosted: Wed Sep 19, 2007 9:55 pm
Hi mini mad
I didn't torque it, do you know the setting. I've checked everythng else and they look ok.
Andy
PostPosted: Wed Sep 19, 2007 10:15 pm
Did you just tighten the nut as tight as you could? or what? be careful, if you over tightened the CV thread may be cactus :( Not likely if it is the cause of play though...
If you hold the wheel at 12 and 6 and try to wiggle it is there any play/movement?
These are the torque settings:
If Drum Brakes - 60ft/lb
If Disk Brakes - 150ft/lb
8)
<edit> be careful with this because if that nut comes undone, you will probably become a passenger :shock:
While i'm here did you torque the ball joints up either??
PostPosted: Wed Sep 26, 2007 11:28 pm
I've taken the drive shaft out again and the bearing hasnt stayed in the hub its on the stud plate could the bearing be turning in the hub?
 Post subject: ACTMCC
PostPosted: Thu Sep 27, 2007 6:51 pm
Hi Andy...make contact with the Mini Club....someone local can come around and have a geek at the problem....I wouldn't drive it like it is :idea:
Cheers, Mick
PostPosted: Fri Sep 28, 2007 7:20 am
Thanks mick, I will do that. it's driving me nuts at the moment. But thats what happens when you own an individual like a mini. you either love them or you hate them, theres no in between. true? ps. how do you get a picture inserted like you have. I've tried but it says the file size is too big.
Andy :roll:
I live with fear everyday. but sometimes she lets me race.
 Post subject: noodle
PostPosted: Fri Sep 28, 2007 9:06 am
If you mean the bearing cup or race as some call it hasn't stayed in the hub then you need to noodle the inside edge of the hub so the cup/race is a tight interference fit, if its loose in the hub then it turn and scrub creating noise.
PostPosted: Fri Sep 28, 2007 9:10 am
Noodle?? :?
PostPosted: Fri Sep 28, 2007 9:17 am
Basically you get a hammer and punch, then mark the inner of the hub, as you make a punch mark the outer edge of the indent is pushed up, so say do it in 4 places evenly around the inner edge of hub then should be tight. that help??
PostPosted: Fri Sep 28, 2007 2:30 pm
I'll give it a go thanks mate
 Post subject: Avatar
PostPosted: Fri Sep 28, 2007 4:41 pm
Andy :roll:
Don't usually give forum help...but here goes...it is called an Avatar and I think its limited to something like 100 be 100 pixels...try uploading a picture in update profile.... :D
