It is currently Fri Jun 27, 2025 2:11 am
PostPosted: Fri Sep 21, 2007 1:36 am
well I been on the lookout for some time now, but recently I made a bit of a score 42mm quad throttle bodies that suit a 1400cc sea-doo found their way to my Garage. you can do the math but 4 42mm intakes are the same as a single 84mm in cross sectional area SCORE)
I have heard it all before, it'll be a Bit@h to tune, no factory computer blah blah. Better throttle response, better turbo spool and the best part, since i'm trying a round nose--- I get to get rid of my ugly and big intake manifold YAY
Guess this means I will be building a mean intake and exhaust manifold, and sending em to HPC. That's all for now. Now real news been working on other cars, uni'ing etc. so no progress on the boost ute
and a few conversions:
13B Extend in a 1600
PostPosted: Sun Sep 23, 2007 10:17 am
sweeeet
any pics?
PostPosted: Sun Sep 23, 2007 6:46 pm
nice, good to see you are going to do it.
keep us all posted, good luck
PostPosted: Sun Sep 23, 2007 10:01 pm
Does anyone know the legalities of using an aftermarket computer for rego?
PostPosted: Sun Sep 23, 2007 10:22 pm
It is legal, but you need a full exhaust gas analysis in order to pass.
The reason everyone uses a stock ECU is because they have already been proven to pass this test.
Unless you're on LPG, in which case you can run what you want as it deemed "clean" you aren't required to pass any test or have a catalytic converter.
PostPosted: Sun Sep 23, 2007 10:34 pm
don't know what everyone elses ecu's are like but it pretty easy to get into the honda ones at least and run throttle bodies, boost them and add mapping for silly revs. benefit is it still looks like a stock ecu once it's all done!
Cheers Steve
PostPosted: Tue Sep 25, 2007 12:24 am
hi guy's.
got some photo's up on my picasa (Google images) site:
Gave up trying to get thumbnails to work here, dunno, don't like it as much as the old photobucket but the link's below.
in as much as having to run the aftermarket ECU, I might be able to get away with the stock 4EFTE one on this for getting it going's sake, but I would like one that I can tune a little better not that far after. Kinda thinking it might just be easier to do all that now and out the way
AWDMOKE: another advantage of the LPG is you can run crazy style boost, that's a little unheard of with petrol
PostPosted: Tue Sep 25, 2007 12:34 am
Very compact. How close are the bore of the TBs to lining up with the EFTE inlet ports?
I know this is not a toyota, but this guy knows his stuff when it comes to ITBs:
http://www.redlinegti.com/forum/vth.27729.silicon+throttle+bodies.htm
Might give you some inspiration?
PostPosted: Wed Sep 26, 2007 6:15 pm
cheers for that AWD, nicley done, as I was holding them I will try and put then in line with the rocker cover and the distance between the centres is remarkable close 83mm on the bodies vs 85mm on the head. So the'll be tuned length mani jobbies (haha I'm so descriptive), just gotta find some id42mm trumpets to get them to flow well :D
PostPosted: Fri Sep 28, 2007 8:28 pm
Good score!!
