It is currently Tue Jun 24, 2025 12:24 am
Post new topic Reply to topic  [ 154 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 11  Next
PostPosted: Thu Sep 06, 2007 8:43 pm
skssgn wrote:
very impressed with the high flow design of that EM, and the clearance it and the turbo has to the front of the car. A trial fit in a roundie would be very interesting
You're on!! :wink:
PostPosted: Fri Sep 07, 2007 7:11 am
Archangel007 wrote:
You're on!! :wink:
Two chances of the mani fitting in a morris. Even if it did the big fark off turbo hanging off the thing is another issue.
6 weeks eh, fantastic. I've been waiting a long time to drive one of these things....... :lol: Mine, Tony's, whatever.
PostPosted: Fri Sep 07, 2007 5:11 pm
Me too! :roll:
PostPosted: Fri Sep 07, 2007 6:13 pm
Archangel007 wrote:
Me too! :roll:
hahaha - jeez, even I've driven a starlet powered mini... it's not that good... :P
PostPosted: Sat Sep 08, 2007 5:51 pm
Good Looking Manifold!!! Wish i had the space.
PostPosted: Sat Sep 08, 2007 10:03 pm
I must say, I'm very impressed by the manifold.
Now I'm glad I'm going Leyland, almost bought a roundy! :shock:
PostPosted: Sat Sep 08, 2007 10:20 pm
Way to go Slink!!!! :wink:
PostPosted: Sat Sep 08, 2007 10:29 pm
I was tempted....hahahahah
Anyways, I really do like that exhaust manifold, it's different, and performance aside, when you open the bonnet, it'll be right there in your face, shiney and all.....mmmmmm... 8)
PostPosted: Sat Sep 08, 2007 10:34 pm
Thanks mate!
PostPosted: Mon Sep 10, 2007 2:26 am
Yeah Simon....
PostPosted: Mon Sep 10, 2007 9:24 am
Gordo wrote:
Hey Tricky i was pondering some time ago about these sort of brake discs, i have a similar style with the groves.... Now do you know or does anyone know which way the groves are meant to go? Like in the picture below, the groves are sorta against the drive? Do they do this to enhance braking by making it a rougher (if you like) surface or do they go the other way?
Archangel007 wrote:
Interesting to note... I was watching some rediculous show on channel 9 on the weekend called "Test Drive". Apart from the appalling format of the the show they tested some late model falcadore. The showed a close up of the rotors and the grove was going in the opposite direction to the way its fitted to Tony's car. I'm not for a moment implying that the falcadore had it right , just that it might be worth looking into.
PostPosted: Mon Sep 10, 2007 9:33 am
http://www.lambocars.com/archive/highres/gtrwheel.jpg
PostPosted: Mon Sep 10, 2007 10:37 am
Correct way for the TAROX brakes:
Q. Which way should the grooves face on a grooved/grooved & drilled disc?
A: In the case of the G88 and Sport Japan discs the grooves should radiate outwards towards the rear of the car. A C83 disc should run in the opposite direction.
G88 Orientation
Sport Japan Orientation
PostPosted: Mon Sep 10, 2007 12:02 pm
Well there you go, there's more than one way to skin a cat.
