It is currently Fri Jul 04, 2025 2:19 am
PostPosted: Sat Aug 25, 2007 9:17 am
i get it......trying to upload the pics
making the mini ov ma dreamz
PostPosted: Sat Aug 25, 2007 9:43 am
the engine being removed....
[/img]http://i239.photobucket.com/albums/ff289/chaudhryrulez/4.jpg[/img]
<mod edit> I made your photo links work , copy them straight from the bottom line of the image quotes below the photo in photobucket , it should appear as [img]all%20the%20photobucket%20text[/img] when you paste it and then it will appear as photo's in your post . It takes a bit of time getting the hang of it but then you'll be right . Great looking mini by the way :D
Last edited by chaudhryrulez on Sat Aug 25, 2007 9:47 am, edited 2 times in total.
PostPosted: Sat Aug 25, 2007 9:45 am
Nice MK1.
Good luck with the build. :)
PostPosted: Sat Aug 25, 2007 9:51 am
PostPosted: Sat Aug 25, 2007 10:01 am
here comes the main thingy......
d15bz7.....dual vtec....the engine just reached the workshop...so the head cover is a bit dirty....
PostPosted: Sat Aug 25, 2007 10:11 am
the two vtec solenoids.
PostPosted: Sat Aug 25, 2007 10:21 am
the corolla standing infront of the mini is undergoing a 3sgte swap...
pic of flywheel and gear box....
PostPosted: Sat Aug 25, 2007 10:43 am
Anwar Zafar(AB)the guy im getting dis job done is amongst the very few famous people in pakistan who are into perfomance swaps n tuning......
the engine below is a d15bz7 too but its in a civic 1995....the engine has custom aluminium light weight flywheel,custom light weight pulleys,
n check out the second pic....i see some throttle bodies on it too....
:twisted: this car keeps up wid cars having same weight but more powerful engines like b16 n 4age....
this civic is soon to be tested wid an rx8 6speed type s.....lets see wht the results are....
a 4age 20V powered toyota corona at the workshop
PostPosted: Sat Aug 25, 2007 11:50 am
Very nice, are you going to do the quad throttle body setup too?
PostPosted: Sat Aug 25, 2007 7:14 pm
Gotta love the D-Series!!
:D
PostPosted: Sun Aug 26, 2007 3:30 am
nops.....dat depends on the space i would be left wid in the engine bay....if there is than i will surely go fer da quad throttle body setup....
but me n ma tuner Anwar bhai are looking fer the reliabilty issues first rather than perfomance..when they will b solved...then we will work on perfomance mods
PostPosted: Sun Aug 26, 2007 9:40 am
Sounds like a good idea.
PostPosted: Mon Aug 27, 2007 12:54 pm
the idea is definately good...but lets hope we r able to do justice wid it
