It is currently Tue Jun 24, 2025 11:30 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 29, 2004 10:21 pm
sweet :D
PostPosted: Thu Apr 29, 2004 10:28 pm
When I did the 850 floors I borrowed a portable Cadillac grit blaster from work. Uses steel grit and also has a vac hood around it to suck up all the grit and crud. Similar to a VacuBlast machine. No mess... :D
Probably worth about $5K now though...!
You think your floors are good, until you hit them with a blaster... yech!
PostPosted: Fri Apr 30, 2004 5:34 pm
Supercheap also sell the sand for them too in containers a kinda black oxide - pretty cheap.
It is good cause you can keep sweeping it up and reusing it.
Ben
