OK I've finished them and bolted on- with .016" clearance, valve lift is now 0.365".
Bush bore offset is 1.1mm.
Not bad for a crappy old set of 850/998 pressed steel rockers- so old that the pillars were
alloy. Can't remember when they dropped those and went to cast iron...
The alloy ones often used to collapse under head stud tension = another blown head gasket for you.........
<edit> syntax
<edit 2> rocker ratio is now 1.31:1
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
