It is currently Wed Jul 09, 2025 1:28 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jul 25, 2007 1:25 am
WasabiPimpNinja wrote:
The salt shouldn't be a problem as I'm planning to re-shell Alley, I'm figuring a top speed run on the salt flat could be a fitting end to a shell that I've spent the last 9 years with :P Maybe when I'm done with the shell, if I have fun on the flat, might have a go at chopping it up, try and rake the windscreen, a Clubman Monaco :twisted:
Would the drag be very different between a roundie and a clubby?? (I hope this doesn't start another Clubby Vs Roundie war ;))
As for straight cut gears, I'd love to get some. I think they sound awesome, but I still drive this on the street a fair bit, and I dont know how the SC gears go with town work. I've heard it takes a bit of a "Knack" to use them.. Anyone wanna confirm, disprove this??
This is sounding like more and more fun by the minute :twisted:
The straight cuts are no different to use, they are just noisey as anything...
PostPosted: Wed Jul 25, 2007 9:28 am
H/PRO Aussie record is 129.217mph. Over at Bonneville it's 131.769mph.
PostPosted: Wed Jul 25, 2007 9:34 am
Was that in a standard shell? I'm guessing they were fairly stripped of interior etc? Have you got any more info or link to more info?
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Wed Jul 25, 2007 11:39 am
Production coupe/sedan is not aloud to be modified much (well in terms of body and such). Gotta have an interior.
Production Coupe and Sedan: /PRO (Gas Only)
This category is intended to represent typical transportation vehicles which may be purchased from ANY automobile dealer. 500 examples of the model used must have been produced yearly. In keeping with this intent, the cars are aerodynamically "stone stock" with no body parts allowed which were not part of the manufacturer’s production for the series of the vehicle involved. The engine used must have been available in the model of vehicle used as purchased from ANY automobile dealer. Modified body, body panels, spoilers, air dams, etc. intended for, as accepted or sanctioned by NASCAR, NHRA, SCCA, IMSA, etc., are not permitted for use in this category unless specifically allowed. A manufacturer’s part number does not constitute an original, factory installed body part. Both exterior and interior body panels are considered to be part of a production vehicle and must be mounted in their original relationship to each other. A different displacement size of the same design engine may be used, provided it does not constitue an "Engine Swap" as defined in Section IV-12. Vehicles originally produced as a front wheel drive chassis and converted to rear wheel or four wheel drive chassis are NOT eligible for competition in the Production category. Choice of camshafts, carburetion, and ignition is unlimited. Cylinder heads are limited to original number of valves and port configuration.
It is REQUIRED that vehicles in this category that exceed 200 MPH, or if the existing record is over 200 MPH, must have roof rails.
PRODUCTION RECORDS ARE SUBJECT TO APPROVAL AND WILL BE CERTIFIED ONLY AFTER COMPARISON WITH THE MANUFACTURER’S SPECIFICATIONS FOR THE MODEL ENTERED. THE ENTRANT IS REQUIRED TO PROVIDE SUITABLE DOCUMENTATION.
XX/PRO class is limited to cylinder head port configuration as originally designed. This applies to the XXF and XXO engine classes.
Engine classes allowed are: AA, A, B, C, D, E, F, G, H, I, J, XF, XO, XXO
Edit/ and more...
PRODUCTION COUPE and SEDAN - /PRO (Gas Only )
This class is for American and foreign coupes, sedans, unaltered in height, width or contour, with all stock panels mounted in original relationship to each other. This category does not include cars properly classified as Sports or GT, such as foreign cars without rear seats suitable for continued adult occupancy. It does include Mustangs, Camaros, Barracudas, 1958 or later Thunderbirds, compacts, and other American cars of this type. There must have been 500 produced yearly. Convertible tops and rear windows must be up when running.
The following items must be retained in stock location and of the same year as the body: frame, fenders, hood, grille, drip rails (must not be filled), windows, door handles, window trim, headlights (high and low beam), tail lights, parking lights, stop lights, radiator, both bumpers and horn. Stock gas tank must be fitted, but need not be used. Any transmission, non-quick change rear end, and starter capable of starting engine may be used, so long as the original running gear design is retained.
The following body and chassis modifications may be made: headers, hood scoop, wheel openings (may be radiused), passenger and rear seat may be removed. Air dams and air spoilers identical to factory optional equipment for the body in question may be added, bucket seats may be used, original side panel upholstery or equivalent must remain, minor chrome trim and emblems may be removed.
The following are NOT permitted: streamlining, belly pans, air ducts, air vents, headlight air scoops, chopping, channeling, quick change rear ends, stepped frames, exhaust outlets through the front fenders, or hood, or body, blocked-off grilles or radiators, engine relocation, body or interior gutting, supercharging, engine swaps, taped body or window seams. Rules for this class will be strictly enforced to ensure that cars entered herein are typical of street machines which may be purchased from ANY automobile dealer.
Engine classes allowed are: AA, A, B, C, D, E, F, G, H, I and J, XF, XO & XXO.
PostPosted: Wed Jul 25, 2007 1:00 pm
Yere, I've read the rulebook... Wasn't sure what class those records were running though. I think I might give this a go. Time for some serious maintenance over the next few months.. And more presents :)
-Wasabi
PostPosted: Wed Jul 25, 2007 2:05 pm
Giving land speed racing a go is something I will do atleast once in my life!
PostPosted: Wed Jul 25, 2007 2:10 pm
Forum Graffiti
He's getting confused with dog gears, straight cuts with no syncros... you need to learn to drive all over again with those :? 8)
PostPosted: Wed Jul 25, 2007 2:21 pm
Ah ha, that does ring a bell. He might have been on track and I wasn't listening.. Yes, I could see why they'd call it a dog box if it was sc with no synchros...
-Wasabi
PostPosted: Sun Jul 29, 2007 11:10 pm
On the weekend I sat in a "Stream Liner" which the owner believes is going to set a new world record next year in the Petrol, naturally aspirated category.
He's geared it for 550km/ph - I was sitting in there, strapped in and the guy who I know reasonably well said "do you want me to start it up?" - I'm like, no, no thats close enough for me :-)
We're thinking about doing a field trip out to the salt next year to watch.
PostPosted: Mon Jul 30, 2007 7:32 am
Mmm.. I drove past a scrap yard the other day and saw a couple of belly tanks there. Took all of my will power from pulling and grabbing them and trying someting stupid ;) I'll deffinately be there next year, hopefully with the Mini in tow :P
-Wasabi
PostPosted: Mon Aug 06, 2007 5:42 pm
im still planning on going for it in the near future but need ot sort out funds frst then go for it and see what happens.
www.minicranks.com add me to your watch list and come back again soon, under construction.
