It is currently Wed Jul 09, 2025 5:22 am
 Post subject: my '89 998ccm injection
PostPosted: Fri Jul 20, 2007 5:00 am
having a lot of Rover SPi parts in spare i started to build a 1.0i
and i've found that after 18 years you should clean the heater matrix :shock:
Rover 214 atm ....
PostPosted: Fri Jul 20, 2007 9:25 am
yay go the 1.0i
PostPosted: Fri Jul 20, 2007 9:28 am
nice one, should be a smooth little number :) keep showing the updates on how you go
PostPosted: Fri Jul 20, 2007 9:43 pm
What kind of ecm are you using
PostPosted: Fri Jul 20, 2007 9:53 pm
i will use Megasquirt
at the beginning it will handle fuel only and if it runs ok the MS Extra code will handle spark
Rover 214 atm ....
PostPosted: Sat Jul 21, 2007 7:32 pm
I havent had anything to do with megasquirt but there are a lot of people here in New zealand are using it and all seem to be happy with the system :D
