It is currently Fri Jun 27, 2025 10:10 am
 Post subject: 5E-FE instead of 4E?
PostPosted: Mon Jul 16, 2007 7:17 pm
Forum Graffiti
Hi guys,
Due to all the 4EFTE conversions flying around the place.. I've recently had the idea of sticking a 5E-FE 1.5L nat asp engine in my Mini K.
I'm pretty sure the only difference in the two engines is the block height.
I'm considering the 1.5 over the turbo 1.3 as I dont need turbo power and I dont want to upset the weight balance of the car too much with massive turbos and intercoolers, etc. I also think I'd have more clearance in a roundie with only extractors to worry about and not a turbo.
Would It be a matter of making up a similar subframe to the 4EFTE one and off I go?
I already have a place to do it for me and It seems relatively straight forward, just wanted to check there was nothing thats going to bite me in the ass when I bolt it in... :P
Sam
P.S: I also sized up the 1.5 twin cam engine in my Excel which looks like it would fit :D :wink:
PostPosted: Mon Jul 16, 2007 7:53 pm
Forum Graffiti
Ok so I had another look at my Excel engine and I think it will fit nicely with some massaging... :twisted: I bet that has never been done before!
Its the 5E-FE or the 1.5 Alpha... :?
 Post subject: exel engine
PostPosted: Mon Jul 16, 2007 8:19 pm
If your talking about the exel engine not the toyota engine the exel has a massive gearbox I doubt you will have the room.
PostPosted: Mon Jul 16, 2007 8:21 pm
Forum Graffiti
Length-ways I think its fine, its just where the driveshafts come out looks rather huge... :?
PostPosted: Mon Jul 16, 2007 8:32 pm
Forum Graffiti
Actually the more I think about it, the more I like it! :D
Imagine...
You just got wasted by a Mini AND a Hyundai.. the ultimate shame! :P :lol: :wink:
PostPosted: Mon Jul 16, 2007 8:41 pm
I am still partial to the G13b suzuki twin cam engine revability and reliabilty.
PostPosted: Tue Jul 17, 2007 1:57 pm
G13b are hard to find. Nice little motor but how much better are they than a nicely built up A series?
The ultimate atmo engine would have to be a Honda Vtec, the best being the K series. 2.0L or 2.2L. They have some on the road in USA, and dam, they go hard.
Or I guess a B18 would be fun, not quite as much go as K series but still, more thna enough power! :twisted:
 Post subject: engine
PostPosted: Tue Jul 17, 2007 3:44 pm
they are heaps better standard than a A series built up 100hp ozzy delivered model with 110 hp jap spec plus plenty of performance mods available a mate had a 1310 worked a series I had a standard g13b fuel injected motor left him for dead in all ways take off top end and fuel efficient plus 5 speed standard high tech motor for it day .
PostPosted: Tue Jul 17, 2007 3:46 pm
5e-fe has a much larger inlet track and plenum - big enough to force you to go custom $$
57 Morris minor
88 Rover Mini
 Post subject: Re: engine
PostPosted: Tue Jul 17, 2007 5:46 pm
My mate at work had a stocko G13B bought new.
My 100HP+ modified 1310S used to waste him off the mark to 100KMH at least.
At 100,000 km, his gearbox was toasted- the bearings were shot. :cry:
I like Suzukis too, great motor but I think the gearbox is marginal. This is not an isolated problem he had.
PostPosted: Tue Jul 17, 2007 5:53 pm
G13b sounds like a nice motor, but I think my mini would put out more atws power on a dyno than a Suzuki GTi, not mention my mini is lighter.
But then again, my mini's boosted, so it's a little unfair.
I just don't think a G13b conversion is justified, when a 4EFTE or B16/B18, are so much better.
You could always turbo a G13b though.... that would be fun. :twisted:
 Post subject: g13b
PostPosted: Tue Jul 17, 2007 7:36 pm
G13b turbo 123 kws at wheels only gearbox trouble when you flat shift and take off using 4500 rpm launches . stock engine turbo charged.
Broke one then replaced with cino box all good so far.
then they start breaking .
the motor weighs 60 kilos and gearbox probably another 20 .
light good power pack but yes the toyota starlet motor is the next generation of performance. And readily available.
By the way I have a GTI Turboed aswell ....
 Post subject: Re: 5E-FE instead of 4E?
PostPosted: Tue Jul 17, 2007 7:55 pm
You don't want to upset the weight balance of the car..but you want to stick a 1.5L motor in?
The 4EFTE retains about the exact same weight as an A-series does - My Clubby weighs exactly 700kg with 4EFTE engine and that's about the same as it weighed from the factory...
PostPosted: Tue Jul 17, 2007 8:38 pm
mini's arnt balanced that great to begin with, they are front heavy. and i agree with mini mad on the weight of the engine.
PostPosted: Tue Jul 17, 2007 9:12 pm
Forum Graffiti
An alloy 1.5L. It would weigh the same or less as a cast-iron A-series.
I only want to match or have even less weight in the front than a good A-series. And the way I'm going to add more power to my A-series is by a supercharger, so you have to take into account the added weight from those things also.
A 4efte would be nice :D, and I have by no means discounted it as I can get one for $1600. I'm just trying to figure out whether I can cram it all in there neatly. The only one i've seen done nice and neat in a roundie is a creamy looking one :)
Last edited by spraycanmansam on Fri Jul 20, 2007 6:32 pm, edited 1 time in total.
Users browsing this forum: No registered users and 24 guests
