It is currently Wed Jun 25, 2025 1:35 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sat Dec 18, 2004 1:35 pm
mine hinges forward and u can slide it to the side to totally remove it.
for maintence its 218973987321 times better than a normal roundy.
but for just checking the oil and stuff, it sucks undoing pins just to be under the bonnet for 30 seconds.
as sc850 said. make it legal.
PostPosted: Sun Dec 19, 2004 2:22 am
....UNLESS of course you need to do it when you're at the servo.... unclip the whole front end and pull it off PROUDLY 8)
Watch the people's jaws drop in amazement :shock:
PostPosted: Mon Dec 20, 2004 10:21 am
I've seen some cool sets of four struts what hold the bonnet about a metre off the body to display it at shows - low cost & easy access.
Or how about 4 GAS struts that lift the bonnet straight up at each corner when you pop the bonnet??? Not just for show.........but it would work best for a clubman bonnet, although I imagine if you used unequal length struts (front to back) on a round-nose mini, you could still make it work.
