Just dragging this one up from the archieves because several mentioned that they would like to follow the progress of this project.
Doc - I have managed to aquire a very straight 1969 Morris 1100S manual sedan. In amazingly complete condition. We have a long known history on the vehicle [going back over the past 22 years] We have a paper trail on it going back to purchase as a new vehicle [one owner]
The 1275 engine
runs like a dream which is not too surprising as it has only 34804 original Miles on the clock. Only problem we have at the moment is a seized clutch most likely from being sitting in an open carport for the last 11 years after the previous owner passed away. [This one was littlerally the little old lady story]
Plan:
The donor is being pulled from the Morrie on the first weekend after new year and because of it's almost pristine state, we are not going to play with the internals too much at this point but just drop her in and run it for a while and assess it from there.
So it is an external cleanup and paint job on the engine
Drop in the Nissan dizzy conversion
New coil
Put a new clutch through it
Drop it into Donkey 2 or three weeks later.
In the mean time... I intend to extract the existing motor early while my engine man is doing his thing, and tackle my engine bay. Just a general cleanup, scrape back the rust and give it a quick lick of paint. This one will not be a showroom finish job, that comes later - the idea here is just to tidy it up a little and arrest any further deterioration.
My only concern at the mo is the gearbox on the donor. I hear that the 1100S box was less than desirable, but I am also getting info that this was only on the earlier cars and that the late model ones [like my donor car] had a better setup. All I know for sure at the moment is that it is a 4 speed manual remote box. I suppose time will tell how we go with it. If all else fails, I could always just order in a Jack Knight 5 speed straight cut crash box LOL [yeah right!
Edit: Added - Is it really impossible to use the disk brakes that come on it???????? Seams such a waist to be that close to a disk setup and not be able to use it!
Comments or advice always welcome
Cheers Dat
