It is currently Fri Jun 27, 2025 7:54 pm
PostPosted: Fri Jun 15, 2007 8:42 am
what do you guys think its either this or a F6a/K6a
also this one will cost me far less from a mates wrecking yard
its a cg13de
57 Morris minor
88 Rover Mini
PostPosted: Fri Jun 15, 2007 8:46 am
the nissan march engine?
58 kW... not bad...:)
a fairly recent make too..
PostPosted: Fri Jun 15, 2007 12:45 pm
It's a swap I've considered for a while. Compact litlle 1275cc motor and there is a 930cc supercharged and turbo variant available too.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jun 15, 2007 5:44 pm
yeh they seem to be a tuff little motor. I have not had a chance to measure one up but the pics i've seen over the net they look pretty compact. Put a nice turbo combo on it and i can see it matching a 4efte. Looks like a mini sr20 with that head too haha.
1974 Moke - 998cc
PostPosted: Fri Jun 15, 2007 6:26 pm
If there is room i will turbo it, your right brad it does look like a baby sr it even has chain driven camshafts under that cover
57 Morris minor
88 Rover Mini
PostPosted: Fri Jun 15, 2007 6:57 pm
There's a mostly complete Micra with minor front end damage in the local wreckers. It's been temping me for months. :lol:
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri Jun 15, 2007 8:40 pm
hey brett, they seem like a decent swap but i havent seen a gearbox yet as this ones an auto
upside: :D its all alloy, quite a compact head width and the water pump is close to the block
Down side: :cry: the oil filter is at the back of the block (firewall side)
does anyone know if they are rod or cable shift + hyrdo or cable clutch
57 Morris minor
88 Rover Mini
PostPosted: Fri Jun 15, 2007 8:58 pm
The one in the local yard is on top of another car. I can go and check out the gear linkage and clutch if you like.
Remote mounting the oil filter may be an option.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat Jun 16, 2007 3:24 am
What does it matter that the oil filter is on the other side? Doesn't tjat mean that it can be hidden along with the starter motor, surely the oil filter wont poke out that much....
PostPosted: Sat Jun 16, 2007 10:02 am
it would be a pain in the bum to change
57 Morris minor
88 Rover Mini
PostPosted: Sat Jun 16, 2007 10:10 am
i thought that, too :P
PostPosted: Tue Jun 19, 2007 7:25 pm
we tried a n12 pulsar gearbox today and would you belive it fits :o and its very small but was run behind motors up to 1.6 so it should be strong , he also had 4 in stock so they seem very common and cheap 8)
also a n16 flywheel fitted too 8) isnt it cool when everything is interchangable
the whole engine and box measured up at 74cm long which will fit nice
cheers Paul
57 Morris minor
88 Rover Mini
PostPosted: Tue Jun 19, 2007 9:28 pm
nissan were good at that...
so how much was the gearbox?
PostPosted: Tue Jun 19, 2007 10:45 pm
$150
57 Morris minor
88 Rover Mini
