It is currently Mon Jul 07, 2025 1:48 am
PostPosted: Mon Jun 11, 2007 8:06 pm
can you run a 1360 with a RE-13t cam with no S/c or turbo while running in the motor.
PostPosted: Mon Jun 11, 2007 8:28 pm
Sure can.... :D
PostPosted: Tue Jun 12, 2007 7:41 pm
is there much power differance between RE-13 and RE-13T (with no supercharger or turbo)
PostPosted: Tue Jun 12, 2007 7:54 pm
to answer your question
i have run in my rebuilt 1360 with an re-13T and lowered compression, its not perfect, but still drives really well considering, wasted a couple of 6 cyl commodores with it anyway :mrgreen:
and its better than my 1310 pre-rebuild.
PostPosted: Wed Jun 13, 2007 4:49 pm
I would assume, yes. But not sure.
Let me ask you this. When running in the motor, do you need max power? If you did surely you would run in with boost?
Run in nice and sedately, then crank some boost! 8)
PostPosted: Wed Jun 13, 2007 5:48 pm
There will be a bit less top end as the overlap is less, by around 14°.
But it certainly will not be a slug. 8)
