It is currently Tue Jul 08, 2025 4:23 pm
 Post subject: SNAP!
PostPosted: Sat Jun 09, 2007 8:19 am
Um, i was putting a 998 engine together last night, and i snapped a rod bolt :shock:
Through overtightening due to torque wrench issues, anyway, its got me thinking, if i can snap one, whats the enging going to do to the rest?
these were not stock bolts, stamped with 10 lines and "FX".
so do i try find another, or revert to stock rod bolts.?
998
lightened rods
wade cam.
going for nice revvy smallbore.
PostPosted: Sat Jun 09, 2007 9:02 am
Best rod bolts for a quick smallbore are `Unbrako' brand socket head capscrews, that's what GR uses. Lube em with oil or a smear of molygrease, do up to 40lb/ft, with no lockwasher.
Alternative is go buy ARP race ones from Minispares etc.
I don't trust the standard rodbolts, particularly if S/H. They make an awful mess of the motor and box if they let go. I bought a ventilated one last year. :lol:
PostPosted: Sat Jun 09, 2007 9:07 am
Yea, i have a ventilated 998 block at home also, thats why im woried! worst thing is it was smeered with loktight so i had to get the broken half out fairly quickly!
its been a while since bolt grade school, what does 10 dashes mean?
what are a set of "unbrako" 's worth?
PostPosted: Sat Jun 09, 2007 9:46 am
And I guess, just as importantly, where do you get them?
PostPosted: Sat Jun 09, 2007 9:50 am
See http://www.americanfastener.com/technic ... _steel.asp
can't see any bolts there with 10 marking.
Unbrakos are grade 12 I think. But don't buy Chinese made...
see http://www.unbrako.com/
download the catalog
<edit> I'd avoid ANY fasteners that are plated.. I once peeled the threads off some plated Grade 8 (7/16 UNF) diff bolts before they got up to the torque setting..... :x
PostPosted: Sat Jun 09, 2007 3:16 pm
Is there two rod bolt sizes from factory
PostPosted: Sat Jun 09, 2007 9:02 pm
The smallbores all run a 3/8" UNF hex bolt. Don't have one handy right now but I think were all the same.
The 1275s with S rods (ie small journal crank) use a 3/8" UNF `shaped head' bolt, and nut.
The 1275s with big journal crank (both A series and A+) use 11/32" UNF `shaped head' bolts and nuts.
PostPosted: Sat Jun 09, 2007 11:12 pm
Interesting. S has bigger diametre rod bolts than big journal ones. mmmmmmm yummm 8)
PostPosted: Sat Jun 09, 2007 11:19 pm
That also means they have less meat in the conrod...
6 of one 1/2 dozen of another
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sat Jun 09, 2007 11:28 pm
Bugger!!
Less meat = lighter. Less meat also = more chance of break!
To quote the Blues Brothers, or close enough
Oh no, the motor's thrown a rod!
Ah that's ok. My motors not a race motor.
PostPosted: Sun Jun 10, 2007 12:18 pm
slinkey inc wrote:
Bugger!!
All Cooper S rods are made of EN24V, the good stuff.
Big journal rods for the 1275 A series were 50g heavier than S rods and made from EN19 and later EN16.
A+ rods are nice and light, made of EN15. In spite of this Vizard says they are fine for a 7500 rev limit.
Weakest point on all these 1275 rods is the bolts- if S/H you don't know how old they are or how used. Buy new ones, preferably ARPs. :wink:
