It is currently Fri Jun 27, 2025 8:22 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu May 31, 2007 10:10 pm
Just make sure you use the cement too - otherwise the clamps wont seal the pipes completely - then you have phhhhttt phhhhttt phhhhttt and the gas escapes.
A trick - put it on the pipe thats going to slide INSIDE the bit you are connecting to otherwise you are just goint to scrape it off into the middle of the pipe hence blocking it somewhat. I use U-clamps on the mufflers and double them up on each joint, turning them about 120 degrees to each other so you get a good seal.
You wont look back - have fun installing them(get a friend - hindsight is such a wonderful thing...lol
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Thu May 31, 2007 10:14 pm
i run a maniflow lcb extractor set then take it to an exaust place and get them to put a straight 1.75 inch pipe on it with a small muffler and a decent tip. sound good, look how you want them to and perform well. i have that sort of system on both my road and race car.. never had troubles.. ive been told after a while rc40 systems die off.
Potato
PostPosted: Thu May 31, 2007 10:19 pm
resident alien
resident alien
Yep... I put it on the outside of one and the inside of the other... helps them slide into each other.
I made sure I got someone :) I removed my old system then looked at what needed to go back on, rang my dad and said "Feel like getting dirty?" :lol: And no that isn't a sexual question... I'm NOT from Tassie :P
PostPosted: Thu May 31, 2007 10:26 pm
Marvin - I am glad you clarified your lineage in the last line of your post - was about to take poetic licience on it...lmao
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Jun 01, 2007 8:45 am
I intend to get the new system fitted when the new head goes on, so that might make it a lot easier to fit with the head off ...
No problems with someone helping because I will leave it all for the mechanic to worry about... :wink:
PostPosted: Fri Jun 08, 2007 5:49 pm
This is the exhaust note with the system I have on it at the moment.. 3 in 1 extractors with a small hotdog up front and a 2" straight through muffler on the back end...
http://smokie.ws/img/lsexhaust.wmv
PostPosted: Fri Jun 08, 2007 8:04 pm
what size engine smokie
PostPosted: Fri Jun 08, 2007 9:33 pm
1030cc with a standard 12g202 head... Once I put the new exhaust system on, I will make another video clip but that will probably be a couple of weeks away yet..
PostPosted: Thu Jun 21, 2007 7:23 pm
My new exhaust system arrived a couple of days ago... Could be a couple of weeks before it gets fitted tho.. :(
PostPosted: Fri Jun 22, 2007 7:55 am
Looks good Smokie.
Very familiar :wink: :lol:
I advise installing with head off.
I tried to install on my car and the elbow just before the 2-1 is too big to fit between the engine and the firewall. Take the head off, ot loosen the engine mounts and it should slot straight in.
I hope that you enjoy it.
Spritey!
Lower your standards. Increase your success rate.
PostPosted: Fri Jun 22, 2007 8:17 am
No worries Sprite_Man, there will be a newer, better head being fitted at the same time... :D
PostPosted: Fri Jun 22, 2007 8:27 pm
resident alien
resident alien
Mine's exactly the same and I got it down there without taking the head off.
PostPosted: Fri Jun 22, 2007 8:31 pm
But you are from another planet Marvin so you must be smarter than the average earthling... :wink:
PostPosted: Fri Jun 22, 2007 8:33 pm
resident alien
resident alien
True, true... I'm glad someone other than myself finally realised that!
PostPosted: Fri Jun 22, 2007 9:11 pm
Head does definitely not need removing! :shock:
