It is currently Sat Jul 12, 2025 5:07 pm
 Post subject: Tapping question
PostPosted: Tue Jun 05, 2007 9:49 pm
Hi guys
I pulled a thread while tightening the drive hub to my disc today. I am going to pull the hub off and retap the thread. Does anyone have any hints or tips?. Whould I be better off to drill it out first and start fresh or just tapp it how it is?. also would I be better off using a UNC tap as its a bit courser? or should I use a UNF? or lastly there is enough room inside the disc hub to fit a bolt, should I just do that?
Oh its cast iron.
Thanks everyone
blokeinamoke wrote:
PostPosted: Wed Jun 06, 2007 6:50 am
I'd be drilling out the old thread and replacing it with a helicoil of the original size.
Curly
PostPosted: Wed Jun 06, 2007 6:56 am
I'd be getting a new pair of rotors, they are pretty cheap... helicoiling an old one is not worth it by the time you buy the kit to do it.:wink:
PostPosted: Wed Jun 06, 2007 5:49 pm
One of your local engineering places might weld and tap it for you with the right inducement - cold cans.
Michael N
PostPosted: Wed Jun 06, 2007 7:21 pm
1. You don't weld brake or suspension parts to repair them. illegal. :shock:
2. It's cast iron, welding a stressed iron component like a brake rotor is a recipe for disaster. They crack easily enough if you're unlucky, even unwelded.. :lol:
<edit> trust me, I'm a welding engineer... :wink:
PostPosted: Wed Jun 06, 2007 7:36 pm
I ended up doing the same thing the other day on my car.I drilled and tapped and fitted a helicoil seems to be ok have done a track day with it like that but i am still keeping an eye on it
