It is currently Thu Jun 26, 2025 5:54 am
 Post subject: Centre oil pickup
PostPosted: Mon Dec 13, 2004 4:41 pm
Does anyone know if you can tell if there is a centre oil pickup fitted without dismantling the engine/gearbox?
Like maybe peeking in the sump plug hole?
michael
PostPosted: Mon Dec 13, 2004 4:52 pm
Dont think you can mate...I believe its a strip down :?
PostPosted: Mon Dec 13, 2004 4:57 pm
bugger. :evil: i could always go with plan B - stick it in for the supersprint and see if i get oil surge :D
michael
PostPosted: Mon Dec 13, 2004 4:58 pm
Yes you can-
Method #1- poke something up thru the drain hole `gently' at about 30* to horizontal. If it goes in 4" or more U got a central pickup in there.
If it touches something closer than that, and then feels spongy to push, that's the stocko oil strainer in the RH corner of the box. No centre pickup.
Method #2- let the oil level (cold) get down to or just below the `add oil' mark, then toss it hard around a roundabout. If the oil pressure drops or the oil light blinks it's got a standard pipe & strainer.
Don't make a habit of this, or the bearings will go away.. ask kazjim.... :lol: :cry:
PostPosted: Mon Dec 13, 2004 5:13 pm
Thanks Dr
Prolly should have mentioned that the engine is on the floor at the moment. so method #1 is the go.
i would have to stick it in the car to do #2. since it is intended to be the supersprint motor for next year, i need to have the centre oil pickup, but i did not want to pull it apart if not necessary. The car is not registered, so going on the roundabout would have to be a midnight run anyway :)
The other motor sufferred surge on a couple corners at Oran, but is just a stock 998, so i was not too worried about it.
BTW, the other motor is a K 1098 10Y?/Ta/H , and has double valve springs. Are they standard?
michael
PostPosted: Mon Dec 13, 2004 6:21 pm
Double springs were only standard on Sprite 1098, and I think MG1100 (rare here), with 295 head. Not 1098 Minis, or common Morris 1100 with 202 head.
If it's a 12G295 head then yes they were standard. :wink:
PostPosted: Mon Dec 13, 2004 10:09 pm
I was very purprised that Morris 1100 had double springs on her.
Sorry Micheal I orginaly said no :oops:
other than going around a corner realy fast I was't aware you could find out....Hold Back Jim :oops:
PostPosted: Mon Dec 13, 2004 10:19 pm
I've got one that I might not end up using. The guy who's building my box is pretty busy and won't have time to muck around bending it if it turns out that its blocking reverse.
Hopefully it will go in fine otherwise look out for it in the for sale section :cry:
dewey
dwightgunning.com
PostPosted: Mon Dec 13, 2004 11:25 pm
dewey
Sale here I'll Need one :!:
PostPosted: Tue Dec 14, 2004 6:46 am
Thanks again Dr. Looks like this motor was modded more than i thought, cos its a 12G202 head, but definitely has double springs. it might already have the centre oil pickup too :D .
Thanks for the offer dewey, but looks like gafmo beat me to it :shock:
michael
PostPosted: Tue Dec 14, 2004 6:56 am
Bending it is no big deal- only needs a slight twist to miss. :wink:
PostPosted: Tue Dec 14, 2004 7:34 am
hrm if there's no heating/bending involved I can probably twist his arm to do it.
dewey
dwightgunning.com
PostPosted: Tue Dec 14, 2004 7:20 pm
how much does a centre oil pickup cost? and is it a bitch to fit? that's if the motor is apart (which my a+ is)
i was quoted $800 odd bucks to pull the block of the g/box and inspect all of the g/box install a centre oil pickup and centre main strap.
seems a bit rich :shock:
PostPosted: Tue Dec 14, 2004 8:03 pm
FFS mikey. Who quoted you that!?
Centre pickup is farken easy to fit... even Warren can do one.
Its just two bolts.
PostPosted: Tue Dec 14, 2004 8:53 pm
Its just two bolts.
Little more to it- after the motor is off you need to undo the big bearing retainer, pull the layshaft out, roll the cluster gear out, remove the old oil pipe and strainer, fit the new pipe and ensure it misses reverse, undo it again, refit cluster & shaft, tighten pipe, etc etc.
Of course, when the old strainer is out and you see all the crud in the bottom of the box, you will want to strip and clean it, won't you.. :lol:
Does take a while to do properly.
