It is currently Thu Jun 26, 2025 5:33 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed May 30, 2007 9:44 pm
Doc, I bet finding Graham Russell's Supapipes here in Vic could be a problem... :?
PostPosted: Wed May 30, 2007 9:48 pm
just go direct
PostPosted: Wed May 30, 2007 9:56 pm
ausmini mod
ausmini mod
Call GR - Tell him what you have and what you want (as in performance, etc)
Ask him how much for Supapipes and ask who stocks them if postage is too $$
Shouldnt be though.
I have a set on my 1132... great for a high performance engine.
Peter.
PostPosted: Wed May 30, 2007 10:22 pm
resident alien
resident alien
A couple of months ago I got a set of Maniflow LCB's with a RC-40 twin box setup from Karcraft delivered to my door for just over $400. Quieter than my old system and better fuel economy too. Running on a 1098 with mild cam.
PostPosted: Thu May 31, 2007 4:54 am
I just discovered the 1.3injection manifold!
I`ll give it a go, cause I`m expecting less noise (cast iron)--> and more induction/exhaust-sounds :D
It`s shaped pretty well and has a pretty good place for the oxy-sensor (good for tuning the engine)!
Looks like it has verry good flow capapbilities. And an included heat-shield on top makes the carby feel better.
But... Don`t know if there ever were 1.3is in Australia...?
Jan
PostPosted: Thu May 31, 2007 8:22 am
Slow-Po
No factory 1.3i in Australia, however a few personal and grey imports have trickled in over the years. 8)
PostPosted: Thu May 31, 2007 10:51 am
Smokie wrote:
Anton, the motor I have in the LS is now a 1030cc, 282 cam, 1.75 SU and soon to have a better head fitted so maybe a LCB system is the way to go along with the RC-40??
Yeah I reckon there would be benefit with fitting some LCB extractors. About $265 but in your case probably worth it since the engine has had a bit of work. I run the three into ones and I'm reluctant to go to LCB system as they're a PITA to work with compared with simple three into ones. As Rob said, not too hard if you have two people, a bit stressful trying to fit it all up by yourself, but is possible.
PostPosted: Thu May 31, 2007 2:47 pm
i wonder who gave you a hint :wink:
for the one who don't know its shaped like a LCB with a bit smaller bore (inside 29mm)
Rover 214 atm ....
PostPosted: Thu May 31, 2007 8:31 pm
Well, going to order these from Karcraft tomorrow..
RC40-001 front engine pipe
RC40 EXHAUST MUFFLER+T/PIPE - MINI (TWIN BOX)
EXTRACTORS - LCB - MINI (MANIFLOW UK)
All up with postage $407.19
PostPosted: Thu May 31, 2007 8:41 pm
resident alien
resident alien
Yep, that's what I got... have you got the clamps etc. too?
PostPosted: Thu May 31, 2007 8:47 pm
Nope but will probably have it all mig welded together anyway... No leaks that way...
PostPosted: Thu May 31, 2007 8:51 pm
resident alien
resident alien
The RC40-001 front engine pipe will need to be cut/shortened to fit too.
PostPosted: Thu May 31, 2007 9:14 pm
Hmmm... Don`t know ;-D Do you know him!? :D
Here`s a picture of it:
http://www.mini-mayfair.net/blog/fish/spi-krummer2.jpg
But please do not weld together y-piece and manifold ;)
It`s kind of difficult to remoce the LCBeast if weldet to the exhaust ;) :D
Clamps do their job pretty well at this point!
PostPosted: Thu May 31, 2007 9:20 pm
Well, might not weld them but I am sure I can get clamps down here to suit...
PostPosted: Thu May 31, 2007 9:26 pm
resident alien
resident alien
The Y piece has it's own clamps on it and the first join is under the car ie. the extractors already have the bend in them to go under the car. I used exhaust cement on all joins too.
