It is currently Mon Jul 28, 2025 2:03 am
PostPosted: Wed May 30, 2007 1:54 pm
I used to just get in and drive the thing, only checking oil, coolant, clutch and brake fluid/s levels once a week. Unless I noticed any dramatic changes in temperature braking ability and all that I would just drive her.
PostPosted: Wed May 30, 2007 6:09 pm
Same as 1360 LS but with tyre pressures once a month and check to see if waterproofing is working after a good rain.
Michael N
PostPosted: Wed May 30, 2007 6:24 pm
Zack
Any news on the Ls ????????
Not been found in some quite side street has it.
PostPosted: Wed May 30, 2007 6:27 pm
I saw an elderly woman with a campervan on an ABC show a couple of years ago and she had a saying that she followed each time she moved camp . "The vehicle needs POWER , Petrol , Oil , Water , Elactric's , Rubber , check them each time you move on ..."
PostPosted: Sat Jun 09, 2007 11:15 am
I'm Ernie , Where's Bert ?
sorry to dig up the dead (posts)
but what EXACTLY is the fluid you put into the 2 resoviours on the left hand side of the engine bay...the Brake And Clutch ones i mean...
Just not sure of the EXACT product i need to get to fill em up.....ie Castrol bla bla bla
00' Forester GT
PostPosted: Sat Jun 09, 2007 11:22 am
Brake fluid.
Not silicone brake fluid but normal brake fluid, about 5 to 7 dollars a bottle. Same for the clutch cylinder, just use normal brake fluid.
Don't allow yourself to get to concerned with the brand or DOT number on it.
Don't put anything else in the resevoir as it will stuff your whole brake or clutch system up.
Don't reuse old fluid, and keep the lid on as much as you can, it absorbs water from the atmosphere which destroys your braking peformance (turns to steam under pressure).
PostPosted: Sat Jun 09, 2007 11:28 am
thanks mick your a legend :D
00' Forester GT
Users browsing this forum: Bing [Bot] and 89 guests
