It is currently Mon Jun 23, 2025 7:46 am
Post new topic Reply to topic  [ 411 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 28  Next
PostPosted: Tue Apr 24, 2007 9:36 pm
man with hydro's that thing is gona be bouncing off the ground.....Its gona be soo cool.
Mini Less at the moment :( Broken Again
PostPosted: Wed Apr 25, 2007 12:04 am
hahah thats great work there on the susp. good on u for spending up to get something unique!
PostPosted: Tue May 01, 2007 9:46 pm
Woohoo, i got some new goodies to help my suspension out.. Those rubber cones were begining to piss me off
Life's a garden.... Dig It!
PostPosted: Tue May 01, 2007 9:54 pm
Locally made or imported? and how much?
Roundies Rule !!!
PostPosted: Tue May 01, 2007 9:58 pm
I bought them from the states. I think you can buy them off some places here in Aus but they are pricey. And i think it was a little over $500 sent
PostPosted: Fri May 04, 2007 10:44 am
it's really only a little bit more than buying a set of new rubber cones $100 each.... "they" say those springs are not real good on the road, but no-one has first hand experience - of course with your bouncy bouncy it's not the same deal anyway!
PostPosted: Fri May 04, 2007 5:34 pm
In my opinion the springs have to be better than the 40 year old rubbers. And yeah for a 100 bucks a pop for the rubbers, jam that. Not the mention they arnt as wide and fit in a little easier.. I could not get in the rubbers without removing the top suspension arm, and to take that out the motor has to come out :roll:
PostPosted: Mon May 14, 2007 1:42 am
Hi, do you need to alter your bodykit in order to get it fit perfect with bolt on?
Becuase I just received a set of zeemax yesterday and trying to trial fit onto my morris round nose, but I can't get the front wheel arch and rear bar sit flash to the body. Therefore all the pieces can't joint aren't meet each other.
the rear arch can be sit flash to the body but the actual car body wheel arch will about 4cm if you look from the bottom up.
So I really don't get it why.
Would you please give me an guidance, if possible you can take some pics to let me see how you do.
Thank you
Regards,
Benny
my email is [email protected]
PostPosted: Mon May 14, 2007 6:29 pm
Benny, mine didnt fit too bad. But saying that it does require a little be it modifing to fit it. The obvious standard mod it the external hinges, that and the guards on my van required cutting cause you could see the pannels under the flairs. Ill send you an email of mine sorta trial fitted
PostPosted: Mon May 14, 2007 7:51 pm
Hi Gordo/Benny,
The kit I recieved from Zeemax was pure shite!!
It was poorly made, poorly finished and a terrible fit.
For the money I paid, I was better off to go to a mould-maker here in Oz and own the moulds myself.
Another lesson learnt!
Gordo, can you send your pics to me as well?
Tricky
PostPosted: Tue May 15, 2007 1:06 am
Thanks Gordo
It's exactly how it come across to me now. I thought is my car body's problem, referred to what zeemax mentioned of their products aren't like other replica require mod here n there.
the quality is alright but the shape to match with the body is absolutely shocking man.
If you can send me some shots of where I need to cut or bogs etc....the worst thing is the front/rear fender panel under the flares :cry:
I'm not sure whether the length of each peices require to cut or not.
please give me an guidance if possible
Thank you
PostPosted: Wed May 16, 2007 1:44 am
Hey Gordo
Do you think that spring and good?
I'm going to order a set from USA soon.
PostPosted: Wed May 16, 2007 1:47 am
Did you bought from MiniMania.com?
How long does it take you to wait for it arrive?
PostPosted: Mon Sep 03, 2007 6:27 pm
Ahh finally a little more progress...
The exhaust was done last week in 3" mild steel, with a stainless highflow cat and a stainless cannon and a flex joint. Now when i went in to the exhaust shop to get a price for the exhaust i wanted the whole thing in stainless stell from the dump pipe back. And this is what i got when i turned up to pay for it......
Needless to say i was not happy at all! So because it was only around the corner from my house i pushed it home and mulled it over for the night. I could not put myself through going with the mild steel pipe. So i pushed it back and told them to make the whole thing out of stainless, but ths time from the flex joint back. So the dump and the manifold are all going to be ceramic coated and should be finshed by the end of the week. Here are some pics of the exhaust in mild steel which has now been taken of to be fixed to the way i want it
PostPosted: Mon Sep 03, 2007 8:11 pm
Yeah Baby!!!
:D
