It is currently Tue Jul 08, 2025 12:26 am
 Post subject: 123ignition Australia
PostPosted: Sun May 06, 2007 10:39 am
Since Pottsy write-up in the Mini Experience,has any one purchased or tried this system?
Thanks.
PostPosted: Tue May 08, 2007 7:39 am
I swapped out my Pulsar dizzy for a 123 a few weeks ago. It starts up, idles and runs much more smoothly and for the first time since before owning the Hitachi, the power curve is where it should be. I was never able to get the engine to respond correctly with the Hitachi. It either had good low end power but knocked at high RPM or was hard starting and had no bottom end.
The 123 is plug and play, and my car has never run better.
PostPosted: Tue May 08, 2007 9:06 am
I want to have Al's babies
Search is your friend. 8)
PostPosted: Tue May 08, 2007 9:33 am
Hmmm-Thanks for that :)
PostPosted: Tue May 08, 2007 9:39 am
No probs. :) This has been a very popular topic in the past...
PostPosted: Tue May 08, 2007 10:16 pm
A friend of mine has one (Kev) & i`m big a fan of them because of his, very very nice
I`d like one now too ,but my new engine doesn`t have a distributor, so ,,,welll,,,er,,,ar,,, no point me getting one really hey? :-)
PostPosted: Thu May 10, 2007 5:53 pm
Anyone tried the 123 with the sc12 supercharger kit? I wonder if it would work OK? or would the timing curve required be beyond the 123
PostPosted: Thu May 10, 2007 7:56 pm
From what I have searched and read,it looks like the 123ignition dizzy has a limitation on maximum revs.I'm still doing re-search :)
PostPosted: Fri May 11, 2007 8:06 pm
The website indicates max revs at 7000rpm, but I wonder if the advance or curve requirements for running a supercharger would be outside what the 123 can handle
http://www.123ignition.nl/brand/Mini.html
PostPosted: Fri May 11, 2007 11:32 pm
I 'spose it'd be fine. As you want less total advance so you statically time it elss say 5 degrees BTDC instead of the more usual, N/A 10 degrees BTDC.
I've done that with a Pulsar dizzy and it seems to work good.
