It is currently Thu Jul 10, 2025 9:40 am
Post new topic Reply to topic  [ 116 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Sun Apr 29, 2007 12:29 pm
well,,, that`s why i don`t bother welding the head at all... the distortion caused by alloy welding just isn`t the sort of thing i like very much & there`s no need to weld the head anyway. If you do weld it, then you`d be wanting to have all the cam tunnels line bored etc etc etc,
there are other people/companies who do weld the heads , not me tho, bugga that, there`s simply no need to
For the sake of a small piece of alloy plate, shaped to suit the bottom of the front of the cyl head to seal off the front head plate, just some devcon & grub screws is all that`s needed, everything else just bolts up to it.
easy-peasy
PostPosted: Mon Apr 30, 2007 9:53 pm
which devcon will work best?
according to my research z-spar splash zone is the stuff to get..but you can't get it were I live
no time to finish me bleedin car ..
1982 Blue-White Roof.
http://aseriesmodifications.wordpress.com/
PostPosted: Wed May 02, 2007 8:41 pm
I actually thought "Devcon" was a brand, i`ve been using it for years & years & just buy it from the brearing shop
you can get Devcon to suit alloy or steel etc, so you will want the stuff for alloy of course
sorry i`m not much help tonight
PostPosted: Thu May 03, 2007 12:10 pm
Like this?
PostPosted: Thu May 03, 2007 2:54 pm
found some of morspeeds conversions video's here
http://www.youtube.com/results?search_q ... rch=Search
PostPosted: Thu May 17, 2007 2:16 pm
hey matt is it possible to use the k1100 ecu?
PostPosted: Thu May 17, 2007 2:43 pm
I`m going to be using the k1000 8v head on a 998 & use all the ecu stuff from the bike in N/A form soon just for the sake of cheapness & ease, i have plenty of those cyl heads & computers & plenty of 998 donks
But i wasn`t going to play with the 16v 1100 ecu simply because there are far better computers out there that are more "Playable" & suit forced induction systems to boot, so i expect you could use one but would have to be a fairly small engine (like 1100) for the std Bimmer computer parameters to be able to cope, otherwise maybe try it with a 1275 & up the fuel pressure etc ... might work i just havn`t bothered to try.
My conversion kits are happening, Bruce has done all the timing plates & all the upper pulley bosses,,,, he`s in the middle of all the lower (mini cam) pulley bosses now & i`ve just ordered & pre-paid for all the pulleys ex japan (ETA 6 weeks i`m told) so now we just have all the upper cyl head plates to do & we will be close to being able to sell some kits to all you lovely people
PostPosted: Tue May 29, 2007 1:26 am
Firstly hello to all , great forum, I've been lurking a while but thought it about time I joined up! as you'll gather my names John and I run Specialist Components in the UK - Hi to Matt and Sir Yun hope you guys are doing well.
I thought you may like to see some vids of our little demo car in action, its a 1293c bottom end runnng 21253 pistons 10:1 comp, bog std K100 twin cam 8v head/cams/throttle bodies (how tempted was I to tickle the ports on this one!) its running our kit/manifold/ecu etc and was built to show what could be done on a budget 8v build. One vid is from the dyno mapping session (figs at the fly) - look how flat the torque curve is from 2500 to 7600 (something you'll not see from a 5 port with this power) - its very torquey below 2500, thats just where the load was captured. The other clip is from a little bit of fun on the road. I've only included the sporty bits as it sounds so "normal" just driving around! - 7k change up point.
whack the volume up and enjoy!
http://www.youtube.com/watch?v=WBToBq6Oejo
http://www.youtube.com/watch?v=974kBWoZ ... ted&search
John
PostPosted: Tue May 29, 2007 1:37 am
why don't you try it on an 850 first?
then you can give that to me, then get on with the fast ones.. :)
PostPosted: Tue May 29, 2007 8:47 am
welcome johnk, the clubby estate looks and drives well. why did you go for the 8v as opposed to the 16v?
PostPosted: Tue May 29, 2007 12:19 pm
johnk wrote:
welcome johnk, i watched those videos a while ago..
and then again... and again.... and again...
such sweet exhaust note... :)
still ... nnothing compares to the sounds of this beauty....
http://www.youtube.com/watch?v=H70vEq_F ... ed&search=
so perfectly tuned too.... :P
PostPosted: Tue May 29, 2007 6:43 pm
Getting more and more interested in doing this :wink:
PostPosted: Tue May 29, 2007 11:03 pm
The Forkmeister
Yeh I agree Gaf, i am getting very interested, come on Matt..... :P
May the fork be with you.
PostPosted: Wed May 30, 2007 10:12 am
Hi John, good to see you here at last, great stuff with your demo minis,
& yeah guys i`m getting there with my conversion kits, we have all our BMW cam pulley bosses done,,, all our timing plates are finished,,, we are finishing off all the mini cam bosses as i type this,,, & i`ve ordered & paid for all the actual pulleys from Japan (60 of them $$$ OUCH!!!) :-) & they will be here in about 4 weeks,,, so we are only left with the cyl head front plates to do & we have decided to modify the program slightly from our original so we are having a bit of fun sorting all that out being that the front of the 8v differs slightly from the front of the 16v head,,, but i will have a full compliment of all the bits to show off at the Mini Muster if you`re interested in having a gork.
I know i`ve been saying it for some time now, but it is happening & won`t be long till they`re done.
If anyone is too impatient to wait for my kit then i`m sure John can accomodate you with one of his conversion kits from England, i believe they cost about $1800 ->plus freight ->plus import duty -> plus GST.
PostPosted: Wed May 30, 2007 10:27 am
and less than $250 dollars aswell... :P
