It is currently Sun Jun 22, 2025 11:43 am
PostPosted: Sun Apr 29, 2007 10:03 pm
Hi Guys
Just a quickie to see peoples thoughts on this.
I was looking at the starlet rack the other night and I reckon I could make it fit the 1100. It looks to be about the same length, between inner tie rod ends, as a mini one (therefore a touch shorter than my 1100 one).
Would having power steering help control torque steer? Or am I creating more work, and possible bump-steer issues for no real gain?
Madmorrie
PostPosted: Sun Apr 29, 2007 10:20 pm
Proper torque steer is turning of the car with the wheels pointing straight ahead. It's caused by the drive shafts being different lengths. Putting in power steering will assist you making the car track straight but it won't stop scaring the crap out of passengers as they watch you battle with the wheel.
I am hoping to get an incar vid to show people what it looks like.
Daniel
PostPosted: Sun Apr 29, 2007 10:32 pm
I know what it feels like and it scares the crap out of you when it happens.
but its fun.
Dan
PostPosted: Mon Apr 30, 2007 8:10 am
Do you know anyone that owns a GT Starlet (if so take it for a drive)? Maybe post the question on Austarlet as some of the guys there take the P/S off.
JC
PostPosted: Mon Apr 30, 2007 9:51 am
I had a drive of Brad's 4efte clubman, scared the living crap out of me.... but bags of fun!
my honda has equal length driveshafts 8)
actually, if anyone is keen, I have a spare equaliser shaft, you could have a go at adapting it to a starlet
PostPosted: Mon Apr 30, 2007 10:36 am
It will make your job of fighting torque steer less physically demanding, but will rob you of some power & add weight. That is why some people remove it. Given a sensible steering wheel size & reasonable upper body strength, you'd be best off without it IMHO
PostPosted: Mon Apr 30, 2007 6:42 pm
Mini torque steer in action (have a look at the front wheel angles under acceleration):
http://www.spagweb.com/v8mini/doris/05/ ... uphill.avi
PostPosted: Mon Apr 30, 2007 7:47 pm
A corolla 4age 20v gearbox has an equalizing shaft that fits a starlet box ( just have to make a new mount on engine end). I fitted one to my conversion and it has no torque steer.
As people have said power steer will help you hold it better but won't stop it. And you could very possible cause bump steer problems fitting the starlet rack.
4efte powered Clubman
supercharged 998 race car
PostPosted: Mon Apr 30, 2007 9:14 pm
Thanks for you input guys. My car will be a daily driver so I don't want to be worried it will dive sideways under a truck or off the road.
Sounds like 92 has the best solution. Will see if I can hunt down one of these equalizing shafts.
92 - Do I understand correctly that with a new mount this will fit straight into the starlet box? Any chance of a pic?
Madmorrie
PostPosted: Tue May 01, 2007 7:39 pm
The shaft is like an inner tripot but about 400mm long and the spiline slots into the gearbox and on the outer end where the drive shaft fits it has a support bearing and bracket, the bracket will have to be made to suit a 4EFTE . I 'll try and take a pic of it
PostPosted: Tue May 01, 2007 8:28 pm
Thanks 92
Found this pics in my collection of 20v images.
[/img]http://www.counterfeitimage.com/morris/images/ae101_20V_driveshafts.jpg[img]
I assume yours looks similar to this. Would love to see some detail on your mount though.
Madmorrie[/img]
PostPosted: Tue May 01, 2007 8:29 pm
Somethign screwy happened there...
PostPosted: Tue May 01, 2007 8:41 pm
You will have to shorten both shafts plus the fixed extension to make the whole system work.
I just had my car aligned and when i say aligned i mean by a person who knows minis and understands how to align them not just an apprentice at a run off the mill tyre place.
Anyway on the way home i put the boot in and was quite suprised at how little torque steer seemed to be present, I'll try it out again this weekend to make sure i was not dreaming :lol:
Dan
PostPosted: Tue May 01, 2007 9:19 pm
minimetoy wrote:
Anyway on the way home i put the boot in and was quite surprised at how little torque steer seemed to be present, I'll try it out again this weekend to make sure i was not dreaming.
"ooor come on officer, i was only trying to see if it would torque steer".
PostPosted: Tue May 01, 2007 10:17 pm
:lol: :lol: :lol: :lol:
