It is currently Wed Jul 09, 2025 10:43 pm
Post new topic Reply to topic  [ 116 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
PostPosted: Sat Apr 14, 2007 6:05 pm
Everywhere ay?
A bit like SC12-ed Mini's??
Gone will be the days of stocko mini's driving around. 8)
PostPosted: Sat Apr 14, 2007 6:17 pm
Maybe it will be a better option to ditch the SC12 setup idea and twinky it instead.....
PostPosted: Sat Apr 14, 2007 10:50 pm
Thought about this.
Went online to check my bank statement...Computer says no twinky.
PostPosted: Sun Apr 15, 2007 10:57 am
1970 mini K wrote:
It would cost at least 4-500 for the injectors alone, then add pump/filter/rail/puter/wiring/throttle body/etc
i bought a 16v head from matt a while ago, it came with quad throttle and injectors etc. so all we have to get is a computer and a pump
:) i hope the kits ready shortly because my car gets painted in a couple of weeks
I was talking about adding EFI to any conventional engine, ie carby - not one that has EFI already :roll:
PostPosted: Sun Apr 15, 2007 1:56 pm
I was talking about adding EFI to any conventional engine, ie carby - not one that has EFI already Rolling Eyes
ok then
PostPosted: Mon Apr 23, 2007 6:12 pm
will the head clear the bonnet without a bulge or does it need mods.
PostPosted: Mon Apr 23, 2007 8:13 pm
Yes. No bulge required.
PostPosted: Mon Apr 23, 2007 9:32 pm
only in your pants
PostPosted: Tue Apr 24, 2007 8:43 am
my mate is making up GOOD QUALITY fibreglass bonnets especially for the bmw heads, i've been told the cross bracing needs to be removed, if the head sits that close to the bonnet i think the heat will stretch the metal and screw up paint.
hence the fibreglass bonnets
PostPosted: Tue Apr 24, 2007 12:32 pm
yes, the front half of the cross member does need to go , (on the round nose bricks) & sickaflex the back half back onto the bonnet so it stays hard.
But no buldge needed,,, (in the bonnet that is) & the heat hasn`t done anything to my paint (yet) but i can see the turbo is going to play havoc with it so i`m buying that alloy square section heat shielding stuff to help stop it damaging anything in the future.
PostPosted: Tue Apr 24, 2007 1:08 pm
What does the Bimmer head do for torque - while horses are well and good, does the conversion suffer the same issues as the bike they are off - no torque below about a million rpm or is that unknown at this stage.
PostPosted: Tue Apr 24, 2007 1:55 pm
The Bimmers have excellent torque compared to most of the late Jap bikes, The Bimmer is rated at 100hp at 8000rpms where most jap bikes produce their peak HP at much higher
& yeah, my first bimmer (during test & tune sessions) kept spinning wheels & then ended up fried the clutch & we hadn`t tuned it past 4500rpms at that stage, so don`tbe fooled, they have the goods alol the way through that`s for sure
PostPosted: Tue Apr 24, 2007 2:21 pm
yep got that but I would like to get an eta of nm (lb/ft) rather than kw (hp). Some may be interested as hp solutions, others, like me , are intersted for grunt potential at low to midling revs (2-3500 rpm).
As for the bikes I dumped my BMW four for a BMW flat twin because of the lack of torque. Top end hp aint my thing, but I will say they are far better than big Jap bikes for torque, but that aint hard.
PostPosted: Sat Apr 28, 2007 8:15 pm
judging from the head and port diameters good torque should be available when fitted with the right induction lenghts.
btw.
does the welding to the head not play havoc with the heat treatment of the head ???? I am temped to solder the needed bit to the head bit I first have to try and find a scrap alloy head for practice.
has anhone had expeiences with this stuff:
www.easyweld.com
or the dodgydly named www.muggyweld.com
no time to finish me bleedin car ..
1982 Blue-White Roof.
http://aseriesmodifications.wordpress.com/
PostPosted: Sun Apr 29, 2007 10:28 am
Yes, I've used that aluminium "welding" stuff. Its closer to soldering than welding, but the aluminium is such a good heat conductor that for a big repair you need to get the whole thing up to temperature, then it all melts on you and runs back out. Its probably OK for small repairs, but I gave up and used MIG in the end.
